Question about Olympus FE-170 Digital Camera
My Olympus FE=170/X-760 camera won't turn on when i press the power button
  • 919 Answers
SOURCE: olympus FE-310
The reset option is located when you hit the Menu button when in shooting mode - it is on the left hand side of the screen. You would click Reset and press Ok. It will show Reset Yes or No. Select Yes and press Ok. The camera will now be in factory default settings.
Posted on Jan 15, 2009
  • 3 Answers
SOURCE: Camera malfunction
I had a Nikon Coolpix L1 with a very similar fault- the lens would whirr in and out as if seeking then lock either in or out with a 'lens error' message.
Not sure you're going to like the solution: place a paperback book on a strong table, grasp your precious camera firmly in one hand and slam its flat base down as hard as you dare onto the book. Hold it hard to the book as it touches, don't hit and lift up again; more slam effect.
I tried this and it worked beautifully; for a few months. I had to do it once or twice a year.
I got the suggestion from a site similar to this with 10 or so astonished owners who had tried it and couldn't believe it had worked so well!
Aren't digital cameras ****, though? I may go back to 2nd hand 35mm SLR for something that actually works!
Posted on Mar 02, 2009
  • 5 Answers
SOURCE: wont power up
this is hardwere problam so 1.chek power btoon and micro swich nier beattry dor
Posted on Mar 22, 2009
  • 11967 Answers
SOURCE: My Olympus FE-320 will not focus. When I turn the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 22, 2009
Obertelli
  • 3006 Answers
SOURCE: Upon hitting the 'power' button,
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Olympus service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
How do I video tape someone with this camera an olympus FE-210/X-775
Here is what the manual said to do:
macapplezoo_17.jpg Basicly, turn the dial to the little camera icon, then press the shutter (big button) to start recording, and press again to stop.
Hope this Helps!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
PS: Full manual Here
Sep 02, 2011 | Olympus FE-210 Digital Camera
My Olympus fe just stopped working. I changed the batteries and that wasn't the problem. It will not turn on! The viewing window is dark, only the tiny light blinks.
you camera is turned on but the shutter seems not to open the reason you only see a dark screen. remove battery and press and hold power button for one min. reinsert battery and try again. if it still doesnt work it might require to be send to depot.
Sep 07, 2010 | Olympus FE-230 Digital Camera
Does the FE-340 camera have a time delay feature so that we can take our own picture?
Please look for clock sign on buttons to turn on-off timer function.
Press clock symbol button to turn on timer function, press shutter button to start timer (10 seconds delay) to take picture.
Mar 14, 2010 | Olympus FE-340 Digital Camera
The power button does not turn the camera on.
Your lens is probably damaged or stuck(such as beach sand particles caught in it) and needs to be cleaned out or replaced. Olympus repair shop can do this(olympus site online) or a camera shop. It is also possible that the batteries do not have enough power in them.
Sep 01, 2009 | Olympus FE-210 Digital Camera
Wont power up
Mar 22, 2009 | Olympus FE-330 Digital Camera
Olympus FE-210 White LCD screen
Sounds as if this is a repair issue with the image processing chip inside the camera. You may want to call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 11, 2008 | Olympus FE-210 Digital Camera
Olympus fe-210 screen probloms
try the power reset by pressing the power button for about 10 seconds with batteries out... if this does not work then repair
Aug 30, 2008 | Olympus FE-210 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
Problem in Olympus FE-170 Digital Camera
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 13, 2007 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
63 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
