Question about Accurian Televison & Video
Accurian dvd-rw/r recorder/player with VHS --- purchased 7 years ago from Radio shack-- now gives a message "Can Not Record on this disc" with these numbers and letters underneath the message E15 2a037304 . I tried several new packages of dvd-r discs---same message. Is there a setting wrong or is the dvd-burner just plain "shot"? There are NO phone numbers for Accurian customer service technicians to call (frustrating). Can you help by noting that message code given above? Never had ANY problems with the dozens of DVDs burnt from my camcorder vacations, till now. Dean Mickelson deanwm_1@msn.com 541-994-5271
    Top Expert:
  • Accurian Master
  • 44,089 Answers
If it is seven years old, there is a good probability that it no longer can record
Posted on Oct 13, 2013
SOURCE: Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
Posted on Jan 09, 2008
SOURCE: Liteon LVW-5045gDL+ dvd recorder will not burn to blank dvds
SAME HERE. I Have tryed a lens cleaner and seems to be working at the moment
Posted on Jan 15, 2008
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
eswaran73
SOURCE: Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Posted on Nov 08, 2008
SOURCE: my recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Posted on Jun 08, 2010
My dad just purchased a 2004 memorex t.v. with built in dvd and vhs players. He wants to know if he could record a vhs to a dvd on t.v.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
Mar 14, 2011 | Memorex Televison & Video
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
Error code E4 54040990, and E21
use dvd-r they are not as tempermental. plus they are more universal if giving the media to somebody that may be older.
Jun 02, 2009 | Radio Shack Accurian ADR-0106
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Dec 04, 2008 | Radio Shack Accurian ADR-0106
Error code
Try using a DVD / CD cleaner disc in the unit - this might fix the problem.
Post Back here again..
Thank you
May 21, 2008 | Radio Shack Accurian ADR-0106
DVD-RW Unit Replacement
Lite-On DDW-813S mounted in thin sheet aluminum (probably for RF interference reduction.)
http://forums.afterdawn.com/thread_view.cfm/374328
Mar 15, 2008 | Radio Shack Accurian ADR-3223
Dvd is unable to read disk that i recoreded on the lg dvd recorder
It would be nothing to do with the TV.
DVD RW discs only last for so long if you have re-written to them many times they may be just worn out. Or is it with all RW discs?
Are you trying to watch them on the same player you recorded them on or is it a different DVD Player you are trying to watch them on?
Feb 17, 2008 | Televison & Video
Accurian DVD Recorder/Hi-Fi VCR combo
You need to finalize the disc u recorded in order to play on other dvd's. press setup, press disc, press finalize then press yes. Finalization will start, this may take some time depending on the amount to be finalized. Be patient. Good luck.
P.S If u have the manual those steps are on page's 36-37.
Nov 30, 2007 | Radio Shack Accurian ADR-0106
Televison & Video Logo
127 people viewed this question
Top Accurian Televison & Video Experts
ray gallant
Jason Lepak
Jason Lepak
Are you an Accurian Televison and Video Expert? Answer questions, earn points and help others
