Question about Ingersoll Rand Electrical Supplies
Oil seperator i have oil in air line when in use
    Prodigy:
    An expert who has answered 500 questions.
  • Ingersoll Rand Expert
  • 573 Answers
Some oil is common, make sure you haven't over filled the crankcase as this causes too much pressure. The crankcase feeds back to the air filter via a reed valve. If that valve is stuck open the oil will be excessive
Posted on Nov 17, 2013
What would cause compressor oil to migrate to dischage air.
If it is a screw compressor and by you saying you replaced the seperator i would say it it you need to check the scavange line. This is a pipe that goes to the bottom of the seperator filter and sucks any excess oil back into the bottom of the element (pump ) if this is blocked oil will pass down the line insted of going back into compressor. Check pipe on seperator and flex hose going from seperator vessel to bottom of element.
Jul 31, 2014 | OEM Air Compressor Genuine OEM Replacement...
Oil dripping from air filter
Hi Anonymous, oil leaking from your air cleaner is caused by oil carryover from the engine. For what ever reason the breather system is not seperating enough oil mist and air from the piston downstroke. There are cheap and quick easy fixes and there are more exspensive ones. Start by trying the following:
1. Run your oil level half way between the add and full mark when hot.
2. Run oil breather lines from head into a TEE fitting below carb/induction module then a single line into a mini filter under frame.
3. Purchase Arlen Ness Super Sucker.
4. Replace umbrella valves and realign oil pump
5. Upgrade oil pump and cam plate
Good luck
Oct 04, 2013 | 2000 Harley Davidson FLTR-FLTRI Road Glide
Air cleaner blowing oil
Good luck
Sep 01, 2013 | 2005 Harley Davidson FLSTC - FLSTCI...
Blowing oil thru air intake and smoking from rear cylinder
Good luck
May 22, 2013 | 2003 Harley Davidson FLSTFI Fat Boy
Oil coming out of air filter in y 2002 harley
Good luck
Apr 06, 2013 | Harley Davidson FXSTB Night Train...
Oil leaking from air filter 2006 sportster
Good luck
Sep 20, 2012 | 2006 Harley Davidson XL 1200 C Sportster...
Oil leaking from air intake of harley davidson
Good luck
Apr 15, 2012 | 2004 Harley Davidson FXSTD - FXSTDI...
2002 fatboy with oil in the air filter
Good luck
Apr 14, 2012 | 2006 Harley Davidson FXDBI Street Bob
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
Electrical Supplies Logo
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
