Oxc000012f win 8 - Computers & Internet
I have an assus LAPTOP WITH WIN 8, my son install Unbutu erasing win 8, i have repair and recovery discs, how do i proceed to re-install win 8 back.
Restart the computer, press F9 during startup. In some PC's, it is the F4 key. This activates the hidden partition where your factory settings is saved.
Apr 29, 2014 | Computers & Internet
Why winning eleven when running says not properly installed
download the wi 8 fixer....and type the problem on google so i will show a link by whom you can download.
.....................................................cheers:::)))
Apr 27, 2014 | Konami World Soccer: Winning Eleven 8
My laptop model is acer aspire 4830....i am using win-8.now..when i start the pc i give a signal for several minute...after few minute it show blue skin..my touch pad also do not work...i cannot fix the...
Is this a OS upgrade? What was the original OS? Win 7? It's a common problem with OS upgrades, Did you verify the minimum spec requirements for a Win 8 upgrade/install? I would revert back to win 7. Wait for Win 8.1. coming next month. I have both, in my opinion Win 8 is a pig, Win 8.1 is a pig with Lipstick.
Sep 23, 2013 | Acer Aspire Computers & Internet
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
Very slow installation of windows 8 on asus p5kpl/am/ps
Can be a lot of things, can be your hard drive.
Your PC is not set to run win 8, yes people put it on older machines, but some don't realize it's not running properly.
Windows 8 has a call for a CPU that has- PAE, NX, and SSE2 features, if the CPU does not have these you will have problems.
Most all motherboards that now support win 8, have had BIOS updates for the kernel of win 8. Only the newest one's out are set to support win 8, but they had BIOS made for it.
Your system has no BIOS updates at all.
There is a utility that will check your CPU to see if win 8 will run on the system, but you need have the OS working, like win 7.
Read this page, and try and run this utility. It would be best for you to reinstall win 7 and run it.
The only reason win 8 will work better is if it is on a system that was made to run it.
Here is the link to read and the test.
http://www.intowindows.com/how-to-check-if-your-processor-cpu-supports-windows-8/
Mar 18, 2013 | ASUS P5KPL-AM/PS Motherboard
How to reinstall asus for windows 8
You want to reinstall Win 8? Did the laptop come with Win 8? What model Asus? Do you have a Recovery Partition with Win 8?
Jan 11, 2013 | ASUS Computers & Internet
Dual boot win 7/win 8 acer v3-571 wireless adapter not working in win 8
try a different route go to my computer then system properties then device manager select the wireless adapter and uninstall the driver forget the websites that you downloaded from, right click the wirless adapter and update driver software see it it helps you if not it may be that the dual boot is in conflict
Dec 18, 2012 | Acer Aspire V35716643 15.6inch Laptop...
I have i problem with my video card i cant find his setup compatible with win 8
I will assume you did a OS upgrade and didn't check compatibility with Win 8. Did you have Win Vista? Or Win 7 before? That said, drivers for the Video will be on the DELL website. SOMETIMES you can use Win 7 drivers. You may have to change compatibility of the drivers. You didn't say is you had Win 8 32 or 64bit?
Dec 11, 2012 | Dell Vostro A860 Notebook
I have hp pavilion dv500. Yesterday I installed windows 8 and now my laptop types numbers instead of letters. Tried Fn + Numlk. Fn+ Shift+ numlk. But every button types letters.
A common problem when you update to a new OS the drivers have to be sorted out. If you jumped from Vista to Win 8 try using Win 7 drivers. You will have to modify the Win 7 and make the drivers compatible with Win 8.
Nov 30, 2012 | Computers & Internet
Blue screen with a status of oxc000012f
scott_zucker
If you are getting the BSOD please look at the link below to get the actual blue screen code and error message this will help me better see what is going on with your computer.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
Jun 13, 2010 | Computers & Internet
Computers & Internet Logo
619 people viewed this question
David Payne
David Payne
