Question about Carrier 38CKC036 Air Conditioner
WE have a Lennox furnace that is 3 years old. We also have a Lennox AC that is 14 years old. Recently we had a board go bad on the furnace after a series of power outages and it was replaced. We also have had an Aprilaire Humidifier 600 installed since the new computer board. Since the weather has turned cooler and we have the thermostat set in heat mode we have noticed random attempts by the A/C unit outside to come on at which time there is serious draw down of our power in the house to the point the lights are dimming and we can here a loud buzzing at the A/C unit when it tries to run. We have had the company who installed all of this back out here and they did find some loose wiring but the problem persists. What could be causing this and how do we trouble shoot it to get it corrected?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Your furnace uses 115 power & there is a transformer in this unit that powers the low voltage controls. i would say that when they replaced the board they missed some issues with the low voltage control wires. which is likely to be what cause the board to go bad. theses low voltage wires are the only thing that can tell the outside unit to come on. the lights dimming tells me that you have a bad capacitor or need a hard start kit. the lights normally only dim if the compressor doesnt start.
Posted on Oct 15, 2013
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Anyone have the service/installation manual for
HI, THE 351 ON THE MODEL NUMBER SHOWS NOTHING. BUT THE REST IS CORRECT. IF THIS IS A HEAT PUMP, IT WILL HAVE MANY MORE CONTROL WIRES. IF YOU ARE BLOWING THE CONTROL FUSE YOU HAVE A DEAD SHORT. GO TO THE OUTDOOR UNIT AND WRITE DOWN THE COLOR AND AMOUNT OF WIRES COMING OUT OF THE UNIT, AND WHAT COLOR THEY ARE CONNECTED TO. THESE GO BACK TO THE INDOOR UNIT. RED IS ALWAYS YOUR HOT, Y IS FOR COOLING, G IS FOR FAN, AND W IS FOR HEATING. IF YOU HAVE ORANGE, BROWN, PURPLE BLACK AND SO ON COMING FROM THE OUTDOOR UNIT, YOU HAVE A HEAT PUMP. ON A SIMPLE CENTRAL UNIT, ONLY 2 WIRES TO THE OUTDOOR UNIT, RED AND WHITE. RED TO RED, WHITE TO Y ON THE INDOOR UNIT. LOOK AT THE SCHEMATIC ON THE INDOOR AND OUTDOOR UNIT, AND IT WILL SHOW YOU WHAT COLOR GOES WHERE, JUST LOOK AT THE LEGEND FOR THE LOW VOLTAGE CONNECTIONS AND THERMOSTAT, AND FOLLOW IT. YOU WILL NOT NEED ANY MANUAL. MAKE SURE YOUR RED WIRE IS NOT TOUCHING METAL ANYWHERE. KEEP ME POSTED ON THE OUT COME, WE WILL HAVE UP UP AND RUNNING. LET ME KNOW IF YOU HAVE A HEAT PUMP.
SHASTALAKER7
A/C AND HEATING CONTRACTOR
Posted on Mar 16, 2011
I have a Lennox furnace Model G19 and the pilot will not light.e You get the normal clicking sound and the ignitor lights but it seems to be a very small flame and the pilot does not light. The ignit
probably need a new control board. so it sparks but gas not coming on? usually you will hear a click then hear gas coming out. if you have a voltage meter check voltave going to gas valve while ignighter is clicking if you have voltage bad gas valve. you should read about 24 volts at gas valve.
Mar 09, 2014 | Heating & Cooling
Lennox lb50527cc
high limit switch, no proof of flame.
Oct 27, 2013 | Goodman Heating & Cooling
We have Lennox Elite Series furnace and central air. Blower would come on but air cond. did not. He replaced circuit board ECG1, I believe. I don't think he was sure if that would repair problem. Our...
Look at the inside of the cover on the furnace and it will tell you what's the code mean.
I think because was calling for Ac that's why you are having that blinking red light.
Turn furnace off on switch and turn it back on and that should clear error code .
To check your air conditioning unit that's the unit that's outside .
Check to see if contactor is pulled in .if it is and nothing is running then check the capicator. The capicator is the oval metal thing that's tuck next to the capicator with 3 wires attached to it .
If it bulky then it's bad .
That is the most common issue with these unit.
Jun 01, 2017 | Heating & Cooling
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
I have a Lennox Pulse furnace. It's making a
The bearings are bad. You need to replace the motor. Motor cost $75 to $125. Labor is on avg. $150 to $400 with an decent A/C Company . You can try to oil it but its not recommend by Lennox. That furnace at the time they build it was top of the line. Good Luck.
Oct 14, 2009 | Heating & Cooling
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Carrier 38CKC036 Air Conditioner Logo
79 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
