Question about RCA L32HD31 32 in. LCD HDTV
Rca rlcdv3282a-b, i've plugged in a usb key to watch a movie but there is no option in the source menu
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: cannot get picture from satellite box to rca rlcdv3282A-B
A suggestion, unplug set and box from power and after several minutes plug both back to power.
Posted on Dec 15, 2012
How can you access USB option on sharp LED tv without remote?
Some TVs has the manual control to menu down right, on frame. Did you check?
Else, only way is to get a GOOD universal remote. The one used for DirecTV has a control of SOURCE.
Check this manual
http://tv.manualsonline.com/manuals/mfg/directv/rc64.html
Jun 09, 2015 | Sharp LC-29LE440M Multi-System LED TV
Cannot get picture from satellite box to rca rlcdv3282A-B
Dec 15, 2012 | RCA Televison & Video
I have a (i think 20 inch) rca truflat tv and i can't find the channel for video and dvd. the manue didn't help and i don't have the guide"
Press menu on your remote. Press "4" for channel and "4" for video input source. In this menu, you can toggle between s-video and regular video (yellow plug) input. The disadvantage is, if you're like me and you've got a DVD player and and VCR (or maybe a video game system) all hooked up to the same TV, you've got to go through the menu and switch the inputs to watch something else. I'm happy with my digital audio cable; I'll deal with yellow-plug video.
Oct 12, 2011 | RCA TruFlat 27F520T 27" TV
Hi, I have a new one sharp Aquos lc-32d47ua i dont know how to use the usb i read the manual but it talk about a upgrade to the tv i just want to watch movies and music from my usb how can i do...
As you've found from looking at the manual, the USB connector on the TV is only for installing software updates to the set. It's not a source input that you can send movies and music over, so the correct answer to your question is "you can't". At least not directly.
While you can't plug a USB device containing programs directly into the TV, you can use a computer as a program source. The TV has a VGA connector (Input 4) for video from the computer, and an audio input jack for connecting the computer's headphone output. So what you could do is plug your USB device into a laptop computer and connect the computer to the TV. The computer would be doing the actual playback of the programming on the USB device (using Windows Media Player, Winamp or your other player of choice), while the TV acts only as a display device. The manual explains how to select the computer input and adjust the TV resolution.
Sep 13, 2011 | Audio Players & Recorders
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
Connecting my IPod ITouch
you cant view tv with the usb plug you need to buy eather a component or composite ipod video cord
Mar 29, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
The convergence is way off on my projection rca tv - i lost the manual but i have set it before in a menu but caint remember how to get to it Was watching a movie, tv shut off and powered back on by...
It should be in the options menu. If not often RCA will drop the option when the convergence ICs go out and often the set will shut down. Heres alink that should be able to help you get a manual and parts if needed. If they dont have your manual leave an email and they should be able to get one quckly usually within an hour or two.
http://servicemanuals.vstore.ca/
Apr 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
RCA L32HD31 32 in. LCD HDTV Logo
125 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
