Question about Sharp AR-407 Copier
H5-02 Error call for service? Can I reset this somehow
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Please check fusing unit first.
Posted on Jan 07, 2014
Im loacked out of my phone because i somehow i forgot my password.
If you forget the security code means, you can get the master reset code for that one,
What is your mobile and model?
If you have the nokia mobile means, get the master reset code here http://www.prounlocking.com/nokia-dct-master-code-service/rs8wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones.........
Apr 27, 2011 | Cell Phones
I have replace the black ink but not the color, I only need to print in black... Can I bypass error code U162 somehow??
Press and Hold the STOP/RESET button or Cancel/Resume button and wait until it self restart.
Release the STOP/RESET button when the printer is restarting
Jan 20, 2011 | Canon PIXMA MP470 All-in-One Printer
File Error shows up when I try to view photos taken
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C387963&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=144190705&stateId=1 0 144204387
The above link describes the following:
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Another problem may be that the Memory Stick Pro/Duo or Memory Stick Pro used in the camera has dirty contacts, causing this error.
Or, the memory stick pro/duo is damaged somehow.
Remove and blow out the memory chamber with compressed air, and remove from any adapters and clean with compressed air and then reinsert fully into the chamber for the Memory Stick on the camera.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C265373&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=144190804&stateId=1 0 144204763
The above shows how to reset a cyber shot camera from sony.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 26, 2010 | Sony DSC-T70 Digital Camera
I somehow lost my secure wireless network. I
I Suggest you should try resetting your router again
Dec 31, 2009 | D-Link AirPlus DI-524 Wireless Router
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
Konica Minolta Di 3010 - cannot clear trouble message
one thing you can try since you have already removed the fuser you can probably do this but i would not recommend it unless you are familiar and comfortable with the components of the machine turn the copier off remove the back cover you will see in the middle of the machine a metal cover with 4 or 5 screws, behind this cover is the main board it has many wires going to it through out the machine...remove the cover so u can see the board and all its connectors on the board there should be a little black button... turn the machine on press this button and the code should reset. If the code does not reset then the thermistor or thermostats are bad and the fuser needs to be rebuilt. as for the password 8 zeros or 1-8 are the defult passwords for the machine. you can also try 1247....
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Feb 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Changing the mileage clocks
push in on the little mileage reset knob and hold it in for a couple seconds.  Works on cars other than Renault ... hopefully there too.
Oct 30, 2008 | 2000 Renault 181
Fisher pakel water saver washer non stop beeping in cycle
hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Sharp AR-407 Copier Logo
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
