Question about Samsung DVD-V1000 DVD Player/VCR
Blows fuses keeps on blowing fuse as soon as you plug it in
  • 158 Answers
Hi,u need to have the powersupply replaced .
Posted on Oct 15, 2013
4 Suggested Answers
SOURCE: DVD/VCR Samsung
CHECK THE RECTIFIER.
Posted on Jun 11, 2007
  • 104 Answers
SOURCE: 1.6A250V fuse blows on V3500 power circuit board
Your DVD combo use a Switch Mode Power supply.
If you want to give it a bash here is a good guide that explains how they work and how to trouble shoot. http://www.repairfaq.org/sam/smpsfaq.htm
but ...
in 95% of the cases it is a shorted switchmode power transistor and other semiconductors, open fusable resistors, other bad parts. Note: actual cause of failure may be power surge/brownout/lightning strikes, random failure, or primary side electrolytic capacitor(s) with greatly reduced capacity or entirely open - test them before powering up the repaired unit.
Posted on Mar 01, 2010
jdvillanueva
  • 2098 Answers
SOURCE: After I put a fuse in the player, and plug into
Your fuse blown again because you have a short on the circuit. You may visit my link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
I've suspect that you have short on rectifier diode/main filter capacitor/regulator IC/transistor. This is quite fixable.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
Posted on Feb 03, 2011
Hi I have a Polk PSW10 it keeps blowing fuse as soon as I plug it in after replacing fuse
Fuses blow when there's an overload. The most common cause is a shorted semi-conductor in either the power supply or the main amp stage.
Apr 04, 2017 | Audio Players & Recorders
What makes a 1997 Chrysler LHS control fuse keep blowing out
I need more info, I'm not sure what the fuse controls? Where is the fuse located and what is the amp rating?
Could be a faulty component or wiring circuit? Does it blow as soon as you plug it in or after you turn on the key? Does it blow quickly?
Mar 11, 2016 | Chrysler Cars & Trucks
FUSE KEEPS BLOWING
It sounds like the A/C compressor clutch is shorted. You will need to have the clutch and / or the complete compressor replaced.
Mar 21, 2014 | Chevrolet Uplander Cars & Trucks
KEEP BLOWING THE FUSE AS SOON AS IT IS ENTERED IN THE FUSE BOX.
If you can pull the plug from the wiper motor and try fuse. If no change disconnect the plug to the electric windows and try fuse. Unlikly to be in dome light circut unless you have had aftermarket sterio system or other accessory fitted recently
Nov 28, 2012 | Cars & Trucks
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
Main fuse keeps blowing. changed battery and installed radio. brand new fully connected postitive termial, vusually checked all wires coming off battery. some sort of radio relay clciks when radio plugged...
Hello! Identify which fuse is blowing...also, does it blow as soon as it is installed or does it blow when you turn the key? Lastly your not referring to a fusible link but a maxi-fuse...ie...40; Correct?
Oct 16, 2011 | 1994 Chevrolet Suburban
Subwoofer keeps blowing fuses.
THE AMPLIFIER "IC" MAY BE SHORTED!
IC MAY NEED REPLACED.
Apr 10, 2010 | KLH ASW10-120 Subwoofer
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Samsung DVD-V1000 DVD Player/VCR Logo
93 people viewed this question
Henry  Thomas
Henry Thomas
