Question about LG WM2688HWM TROMM SteamWasher
Cracked plastic window in front loader washer
The plastic window in my front load Tromm washer was cracked and broken and I'd like to replace it, where do I find the part?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
Stop Kicking Your Washer!!! First! The glass is a material Hybrid from the NASA Apollo Space Program! That was Some Kick! Can't buy Just the Laminar Plastic Piece. You have to purchase THE ENTIRE DOOR dummy! Go to Sears.com, They will Love your Money and deliver via Space Shuttle Free...LOL
Posted on Dec 17, 2013
  • STEVEN NEUNHOFFER Dec 27, 2013
    Sorry about the Dummy comment! Just trying to be a dopey comic! Really the door is a complete assembly because just the Plastic type Glass is "Sealed" by the factory under extreme pressure!
  • 85 Answers
SOURCE: my front load Tromm LG
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Posted on Dec 21, 2008
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
drsn
  • 42 Answers
SOURCE: TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Posted on Feb 13, 2010
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
Jun 12, 2014 | LG WM-1832C Front Load Washer
Hi, we have a lg wm0532hw tromm front loader washer, the latch on the door seems to be broken, it slides all the way back into the door frame and washer will not lock. Can this be fixed? thank...
I'm sure it can but you will need to call a local service engineer to do it. Sorry we cannot call one for you.
John C
Mar 10, 2011 | LG WM-0532HW Front Load Washer
WINDOW WASHER CONTAINER CRACKED & LEAKING - VOLVO S70
not that hard. you need to remove the wheel arch and its right in front of you
Dec 02, 2009 | 1998 Volvo S70
I have a front loader LG Tromm dryer that has a crack in the drum. Can this be self repaired anad if so how? Thanks
I HAVE REPLACED SEVERAL OF THEM. THE ROLLERS CAN GO BAD AND THE TUB IS SUPER THIN. IT USEUALLY CRACKES AT THE WELD IN THE BACK. THERE MAY BE A RECALL ON THAT BY NOW. THE LG COMPANY MIGHT SEND YOU A NEW TUB AND ROLLERS IF YOU COMPLAIN TO THEM ENOUGH. UNTIL THEN ALUMINUM TAPE IS A TEMPORARY REPAIR
Nov 03, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The washer is leaking water from the bottom. How do I take the washer apart to find the leak?
If its a front loader, it may be the outer plastic casing that is broken. You need to take the whole front off. Call a repair man....Mine has cracked, and needs replacing, I have only had the machine 8 months.
Mar 19, 2009 | GE Washing Machines
Front door plastic face plate of washer HE3t
yes. there aretorque screws around the inside frame remoive them and the 2 pieces will seperate. you can replace it then. be carefull if you remove the screws from the hinge the whole door will fall off. only six or so screws need to be removed
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3 front loader door cracking and broken latch problem
there around 300.00 1 ideal to share buy service smart agreement from sears all parts &labor will be covered up to 500.00 i have warranty it payed off big time
Nov 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
236 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
