Question about Dryers
Hoover Clothes Dryer Apollo 100 D6176
My dryer will not heat up properly or dry clothes.. I was wondering what I can do to fix this without buying a new one.
    Problem Solver:
  • 12 Answers
Most electric dryer problems not heating are due to the heater coil circuit being broken. The wiring can be replaced by the coil kit being purchased from an appliance parts store. Need make and model numbers. Follow directions in package.
Posted on Oct 22, 2013
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
  • 686 Answers
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Posted on Feb 17, 2009
  • 686 Answers
SOURCE: Dryer is working but not heating up or drying clothes
bad heat element
Posted on Feb 20, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
I have a MDG5500AWQ. Without clothes in the dryer it heats up. With clothes in there no heat. On sensor dry it now goes to 99 minutes but doesn't dry properly. Can you help?
not sure but sounds like something wrong with ur sensor? as soon as clothes are placed in the moister is sensed by sensor but trips it?
Oct 10, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Takes too long to dry
Is it heating up at all? I just fixed my vision hd hoover 381 dryer by replacing the heating element. Email me if you think this might be you (matskm@gmail.com). When the dryer is running, feel the metal heater housing (carefully) on the back (silver bulge) if your model is like mine.
Jan 09, 2014 | Hoover VHC391 T-80 Dryer
Hoover hvc 180 not drying clothes
You will need to check the internal, as well as the external vent line for lint buildup.
Apr 28, 2012 | Hoover VHC391 T-80 Dryer
Hoover 5040ed clothes dryer does not heat up enough to dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 02, 2011 | Hoover Dryers
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
No heat, will turn on and spin with cool air only. does not dry clothes.
Okay, let me try to solve this with three possible solutions:
EASY AND CHEAP: Check the hose, the lint filter and the vent for obstructions. If the air is not getting out then the safety switch in the dryer will tell the element not to heat up. Without this safety switch the dryer becomes a fire hazard (and that's a whole other FixYa problem!). Make sure the hose is not crimped or clogged and that the outside vent is opening properly.
HARDER AND MORE EXPENSIVE: The heating element may be burned out or have a loose connection. This is a little bit harder fix but can be done without consulting a repairperson. However, if you have little or no experience then don't try that at home.
EASY BUT MOST EXPENSIVE: Buy a new dryer. If you do, see if the company you buy it from will take a trade in. If not, call a small appliance repair shop and see if they would like to buy your machine to repair and resell. This might offset some of the cost of the new dryer.
Hope this helps. Good luck.
May 26, 2009 | Kenmore Dryers
Dryer not heating Enough
Ceck the vent hose and vent. Make sure these are clear of obstruction. This is tipical of poor venting. The dryer can`t remove the moist air to dry the clothes properly.
Nov 14, 2008 | Hoover HDC6 Electric Dryer
Hi, I've got an older Hoover Apollo 411 tumble dryer which has just stopped heating. It still spins but obviously doesn't dry without heat. I presume that it is some sort of element or heating coil that...
A good Start to clear it up is "repair clinic.com" Sounds like a heating element. Repair Guru will let you know if it is a real problem to fix.
Jun 25, 2008 | Hoover Dryers
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
