Question about Behringer UB2222FXPRO - Eurorack Ub2222fx-pro
How to replace slider/fader EURORACK UB2222FX-PRO
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: I bought a Behringer Eurorack UB2222FX-PRO at a
It is quite possible that you have bought a set that has a faulty preamplifier. The equaliser needs many such mixing preampflifer IC's mostly coupled together and it could be that there is a failure in one or several of the channels, the stages of the preamplifier. You must use a signal test to identify the faulty stage. You will need some help to go through these circuits and identify the op amps that are faulty. Try to check for voltage on the op amp stages and test with an audio signal for the section in fault. Hope you try. Good day.
Posted on Aug 11, 2010
Denon dn-x300
Greetings
can you explain more?
or just the sliding fader is not working?
if the sliding fader is not working u need to change the sliding part
REF: SLIDE VR(RA45D2-211-15D1-R0B50K)
its 50K Ohm slider.
sometimes the material inside the slider ends fast due to activity.
hope this helps
Kind Regards from Audio-adviser.com
Feb 15, 2014 | Denon Dnx300 3-Channel DJ Mixer System
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Left hand slider pitch control needs replaced due to fluid spill.How can I acquire a replacement part in New Zealand.I was playing at a function and a local drunk spilled alcohol on my controller.Im not...
DO NOT USE CONTACT CLEANER !!!!!! It removes the lube.... If you can find it there, use CRC226 in the faders. You MIGHT be able to restore the fader with it. With the spout put a bit right in the center of the slot and work it. Here I get it in the electrical dept of Home Depot... not sure what they have in New Zeeland. Replacing the fader takes a lot of labor as the panel has to be completely disassembled. You can probably order CRC226 online if you can't find it in a store there. Here it is about $2.75 for a can.
Sep 20, 2011 | Behringer Bcd3000 B-control Dj Mixer...
I bought a Behringer Eurorack UB2222FX-PRO at a garage sale. I am getting no signal at all through the channels and no levels appear on the LED VU meter. What could be wrong?
Jun 02, 2010 | Behringer Audio Players & Recorders
Left channel out on behinger ub2222fx-pro could use a service manual. Thanks in advance
Behringer only give the manuals to their authorized service agencies I am told.
Mixers are very symetrical and have lots of diagnostic capability from the outputs.
If you headphones work, chances are the moxer biss es are OK which probably focuses the problem on the output drivers.
Use headphones to see what jacks work... Remember that a stereo headphone will only have sound on one side for the mono jacks you test.
If your mains have a dedicated slider, one half of the slider could be bad. Usually you can tell those by a rougness as you slide them.
Feb 07, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Looking for sliders for mackie 1402 vlz pro how much are they?
You can purchase the channel faders directly from Mackie Service Dept., you can replace them yourself if you're good at soldering - HOWEVER, be advised that disassembling the unit to get at the faders to replace them will require a lot of time and patience if you've never done it before. If the faders are not moving smoothly, it's possible that the wrong type of cleaning spray was used on them and there's a possibility that they could stop moving and controlling sound.
Jul 27, 2009 | Mackie Music
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
SL1210 MK5G PITCH REMOVAL ?
The fader for the M5G's are the same as for the MK5's. As for cleaning, you will have to do it like you did with the MK2, and go from underneath.
DJPROLAB
Jan 31, 2008 | Technics SL-1210M5G Turntable
Behringer UB2222FXPRO - Eurorack Ub2222fx-pro Logo
48 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
