Question about Freezers
Our FJ 303 T-L Westinghouse freezer has the red alarm light on & the freezer isn't getting cold. we have no food in the freezer at present. the fan doesn't appear to be working. what can you suggest please?
  • 108 Answers
SOURCE: White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
Posted on Mar 09, 2009
  • 286 Answers
SOURCE: Frosting up around condensor etc , and the warning light on.
Are you frosting up at the condensor or did you mean the evaporator? If its the condensor then make sure the coils are clean. Still then you will need a tech to look at the seale system. If its the evaporator and the heater is ok then it could be the timer or the terminator on the compressor. Most of the time its the timer.
Posted on Sep 14, 2009
SOURCE: temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Posted on Feb 25, 2010
  • 10 Answers
SOURCE: alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Posted on Mar 11, 2010
  • 4793 Answers
SOURCE: red alarm light came on after we defrosted a
red alarm light is telling you that the feezer is too hot
(above 18c)it should go out when powered up and back to normal temp.
Posted on Mar 24, 2010
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
It is running but is not freezing the food
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
137 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
