Question about GE JGSP28SEKSS Stainless Steel Gas Kitchen Range
GE JGSP28SEN4SS bake and broil do not work - GE JGSP28SEKSS Stainless Steel Gas Kitchen Range
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Gas ovens need a glow bar igniter to operate as a safety feature. if it is broken (and they do go out often) nothing will work. (it stops the gas from coming into the stove if it is broken, (its purpose light any gas and to send a signal to the valve that (yes I'm on and you can keep sending gas) they are always on when the oven is on they never stop glowing... until you turn off the oven.. they are very visible in their glow.. in most oven you can see them like a red hot iron glowing in the oven before it lights the gas.
in the diagram #316 is the igniters
http://www.partselect.com/ModelFrames.aspx?ModelID=1593059&ModelNum=JGSP28SEN4SS&mfgModelNum=&ManufactureID=2&Selected=00133566i01&Position=6&mfg=GE&Type=&Mark=6
This is for your info only call the gas company...or a qualified gas oven repairman. Gas ovens can be dangerous.
If the glow ignitors are working (both) then it could be a valve issue but they need a certain amount of resistance from the glow bar to open. (sometimes even if the glow bars are glowing if they are getting old the resistance is not enough to open the gas valve.)
Posted on Oct 13, 2013
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
  • 126 Answers
SOURCE: Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Posted on Jan 16, 2009
  • 107 Answers
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
  • 713 Answers
SOURCE: Oven's bake funktion does not work
Hi,You need to replace the oven igniter. You will find that this is a very common problem with that model and other models that use this igniter. It is very simple to do.
Look inside the oven and you will find 2 screws at the bottom of the oven in the back. Loosen them up and remove the bottom panel of the oven.
Remove the broiler, and oven trays and it is a 10 minute swap out. Removing the above items allows you the access needed to get to the two screws that mount the oven igniter to the burner.
Using either a socket (1/4") or a nut driver, remove the 2 screws and unplug the igniter. The most difficult part of the exchange is unplugging the igniter. The plastic will most likely break because it has become very brittle by being exposed to the heat. Be careful to break only the part that is being replaced.
If you do happen to break the fittings, they can be replaced with any male/female connector. If you need to replace this, I recommend that you stay away from plastic encased plugs.
You then install the ingiter, plug it in, and you are back in business. It is a very simple part to replace, but it is costly.
Thanks and take care
Posted on Apr 27, 2010
SOURCE: my GE Profile Gas range JGSP48 will not cook on
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one in the list.
Posted on Jul 15, 2010
I have a G E Spectra gas stove and oven the gas oven doesn't work
does it not bake or broil? if this is the case, it could be the control panel. however if one or the other of the bake and broil functions work then it would most likely be an ignitor. check to see if your broil and bake ignitors glow. to access the bake ignitor you must remove the bottom panel from the oven but you can probaly see it gowing without removing the panel. the broil ignitor should be in plain sight.
May 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
GE oven bake igniter is bad ?
Yes, it should work fine to swap them. (fortunately the bake and broil igniters are often the same part number on GE gas ranges, as as opposed to many other brands) Of course now you broil will not work, but you should be able to get your oven going again.
Jul 15, 2009 | Ovens
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Kitchen Ranges Logo
125 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
