Question about Dodge Vehicle Parts & Accessories
Pickup running put in park open door and dashlights flash and horn blows
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Could be driving a stolen vehicle....or you have an add on improperly installed. What was the last thing you had added to your vehicle and go from there. Could be faulty wiring, a dealership could run a system diagnostics and problem would be solved.
Posted on Oct 14, 2013
My 2005 Jeep liberty horn blows for no reason last night at 3 am it went off and the only way i could get it to stop was disconnect batt
double posted. wow.
when it beeped, did you look in the display (RPM)
it tells you why?? the VFD or EVIC tells you why.? (rpm dial)
do you park with the alarm on , on the street or a garage?????
if in a garage park and turn alarm off. it does turn off the alarm.
did you bump the panic button?
eg its under your pillow?? LOL or the cat chewed it?
read your other post, it's got lots of answer there.
to find cause.
if the horns stays off, if alarm is off then its not the horn button.
as many will say. there are 4 things that run the horn.
button horn
alarm
door locks.
panic.(part of alarm but not totally)
on my car, i have most themn turned off, like the lamp flashings.
and the horn chirp is off on all my cars, all i get is the door lock click sounds, nice (neighbor friendly)
so turn all all that and see if the horn still fails.
that panic button can fail,
if mind did id pull the fob battery and then use FOB 2.
to see of the FOB fails.
your other post said driving
this one says, parked. 3am clue.
Jan 19, 2017 | 2005 Jeep Liberty
How do i fix delco anti theft radio security system that won't stop flashing lights
Did you hit the remote button to unlock the doors.? Will the car start?
Jun 09, 2014 | Vehicle Parts & Accessories
I have a 2004 1/2ton pickup, no extras.bare basics. put my headlights on last night and then hibeam turned them off when I got to a main rd and the horn started beeping, the lights flashing.The horn...
Sounds like the horn button on the steering wheel has gone to ground. Look at the harness running up the steering column to see if any wires look pinched or cut.
Apr 14, 2017 | 2004 Dodge Ram 3500 Truck
2009 honda civic lights flashing horn blowing security alarm
try disconnecting the battery neg lead and the pos lead then join them together for 5 mins then reconnect the battery and see what happens ,it might just reset the fault for you .
Apr 27, 2012 | 2009 Honda Civic 1.4
I changed stereo and now the dashlights do not work
Check your park light fuse. You may have blown the fuse for the dashlights/park lights by accidentally grounding the night illumination wire, located in the radio wiring. That wire runs from the dash lights to the radio, to illuminate the radio at night. Alternately, if the park light fuse keeps blowing when you replace it, you might've hooked that night light wire up to the wrong wire on your radio.
Sep 22, 2010 | 1995 Mazda MX-3
Horn blowing
WIRE GOING UP INSIDE STEERING WHEEL HAS PROBERLY BROKE AND SHORTED OUT
Feb 02, 2009 | 2003 Suzuki Vitara
Electrical
Go inside the vehicle,dont put key in ignition, leave driver's door open, press the auto lock button on the driver's door, now close door while you are inside and watch on the dash the alarm enable itself, once it stops flashing open the door, this will set off the alarm, lights flashing horn blowing. Now take the key and put it in the drivers door and turn the key to stop the alarm. Now start you vehicle. If you want you can take the glove box apart to get to the vehicle security module to remove it. Dont unplug it unless the vehicle is running (must be running due to back up on computer) unplug the module and you will never have another problem with the security again and it does not effect your powerlocks.
Jul 09, 2008 | 1995 Jeep Cherokee
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
