Question about XO Vision XO-1400 Car DVD Player
How do i install a STOCK backup camera to a pioneer avh-x5500 bhs? please help thanks
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
Install a pioneer AVH-P6800DVD
Here is a link to the manuals for this device:
http://www.pioneer.co.uk/uk/support/manuals/AVH-P6800DVD/index.html
1st manual is the installation manual, it is mislabled.
Cheers!
Nov 07, 2009 | Pioneer AVH-P6800DVD Car DVD Player
I need the installation manul
Hi jackclayborn,
Below is the web address of the online pdf of the installation manual for your avh-p5000dvd
http://www.service.pioneer-eur.com/peeservice/instrmanuals.nsf/0/FFA105363AF171D4C125743A00324D8C/$File/CRD4274_AVH-P5000DVD.pdf.
Copy then paste this into your browser.
Hope this helps,
Mark.
Mar 29, 2009 | Pioneer AVH-P5000D Car DVD Player
Pioneer AVH P6500DVD/AVIC 80DVD Installed.Pink Purple Green Wire?
can you take the black cage off or maybe you can take a screw driver and bend it back up
Hope this helps
install manual
owners manual
Feb 19, 2009 | Pioneer AVIC-80DVD Car DVD Player
Faceplate avh-6500 vs avh 7500
pioneer electronics website has the avh-p6500 face for 119.00
Mar 13, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer avh-p5700 dvd player
You can download installation and operation manuals at this link (free registration required): http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070347_192089338,00.html
May 26, 2007 | Pioneer AVH-P5700DVD Car DVD Player
XO Vision XO-1400 Car DVD Player Logo
43 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
