Question about Sub-Zero 690 Side by Side Refrigerator
On the top part of the panel light is off where temrature shows . How I could replace the bulb? thanks
    New Friend:
    Problem Solver:
  • 10 Answers
GOOD LUCK,I BELIEVE ITS ON AN LCD PANEL BOARD..ONE UNIT I THINK??
Posted on Oct 13, 2013
Light does not come on when you open door
Test your 40 watt light bulb in another fixture if the light bulb is OK then unplug the refrigerator and open fresh food compartment and pry out the light switch. Test for continuity HERE For some reason your model shows an additional light switch on the control panel located inside the fresh food compartment above top shelf. Try switching the ligh switch on from there. Here is a Photo Click HERE Here is a replacement light switch=> Light-Switch-2149705-00557365 If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Picture on tv screen showing only half picture bottom of screen blackpicture only showing about 6inches at top of screen
good day sir
your problem is on the back light of your TV..the upper side is not function because the back-light lamp is busted and the lower part is good so you have to do is replace the upper side..
I teach you to do that
first,remove the cover of your TV by removing all screw at the back side then you remove the plastic cover of unit
secondly,when you see the inverter board,power supply and main board remove it
thirdly,remove the steel cover of the LCD screen to see the back light bulb or lamp
and finally, after you see the lamp replace it with a new one only the top side lamp is busted so that's the only lamp you replace
thank you
Apr 03, 2011 | Televison & Video
Need new bulb for old slide projector...bulb type is DAK 500 watts - 120 V...was Sylvania Projector Lamp Blue Top. Is there anything available to replace? Thank you. Linda
The only place to get it is online. I used this link from bulbs.com
http://www.bulbs.com/eSpec.aspx?ID=12053&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
Jan 03, 2011 | Televison & Video
Chasnge light for water dispenser
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Apr 25, 2010 | GE Profile Arctica Stainless Steel Top...
GE Advantium SCA 1000 top rear cooking bulb blown
Hi
Thanks for using FixYa. First please disconnect the power of the main fuse or circuit breaker panel and remove the screw from the side of the light compartment cover and lower the cover until it stops. Now gently pull the bulb from the receptacle. Raise the light cover and replace the screw and then connect the oven with the mains and switch it on.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 25, 2009 | GE Advantium SCA1001SS Convection /...
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
Hyandia Accent
not sure which top tail light you mean? do you wish to replace bulb or actual lamp on the rear screen? this is the high level brake light ! OR do you wish to replace bulb in one of the rear tail lamps offside/nearside ? which ever ? the h/level brake light bulb is accessable for bulb from the rear panel on hatch behind lamp bulb is 16 watt capless push in type
Nov 10, 2008 | 2003 Hyundai Accent
Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Sep 01, 2008 | Sub-Zero 680 / F
GE microwave interior light bulb replacement.
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Nov 26, 2007 | GE Advantium 120 Convection/Microwave Oven
Sub-Zero 690 Side by Side Refrigerator Logo
59 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
