My Samsung monitor displays the message "Not optimum mode; recommended mode 1920x1080 60 hertz - Analog" - whenever I try to boot in a Safe Mode (WinXP). It works fine in a normal mode as well as in VGA mode (even with the lowest possible resolution). I manually fixed default settings in registry (HKEY_CURRENT_CONFIG -> System -> CurrentControlSet -> Control -> Video): Xresolution=0x400 (1024) YResolution=0x300 (768), but it didn't help. It seems that VGA doesn't get current resolution settings when loading in the Safe Mode. However it's all right with the CRT monitor. Does anybody have an idea what should be done? - Samuel
    New Friend:
    Problem Solver:
  • 6 Answers
  1. Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open Display.
    Note: Depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
  3. In the Display Properties window, click on the Settings tab.
  4. Toward the bottom of this window, click on the Advanced button.
  5. In the resulting window, which may or may not be tittled Plug and Play Monitor..., click on the Monitor tab.
  6. Locate the Screen refresh rate drop down box in the middle of the window. Under most circumstances, the best choice is the highest rate available. Depending on your issue though, the rate may need to be lowered.
    Note: It is always recommended to keep the Hide modes that this monitor cannot display checkbox checked. Choosing refresh rates outside this range could damage hardware.
  7. Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
Posted on Oct 13, 2013
  • 452 Answers
SOURCE: bios problem
cnge BIOS cell & then try .
Posted on Oct 13, 2007
kykeaton
  • 35 Answers
SOURCE: Monitor resolution re-set with a Samsung MW225 and Windows Vista
yes if your comfortable with editing your registry.
remove the following: (backup your registry first)
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device0]
"DefaultSettings.XResolution"=-
"DefaultSettings.YResolution"=-
"DefaultSettings.BitsPerPel"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\Settings]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device3]
Posted on Feb 23, 2008
rolltape
  • 58 Answers
SOURCE: Samsung SyncMaster 931BF 19" Monitor.
This is because your screen is not compatible with any resoultion past 1280 x 1024. Look at your screen's specifications here: http://downloadcenter.samsung.com/content/UM/200602/20060210090838125_BN59-00521A-01Eng.pdf (Page 76 listed as Maximum resolution)
If you want to go past that, you must purchase and/or use a different monitor. Just be sure to look at the Maximum Resolutions BEFORE you purchase a new monitor!
Posted on Nov 25, 2008
Mellburn
  • 24 Answers
SOURCE: Windows XP operating system does not load.
You need to repair your windows xp installation.
Insert the xp install cd and power off - then power on your pc.
If the screen says "press any key to boot from cd" then do that.
It takes a while until you get to choose options.
Choose the repair previous installation option by pressing the R key when prompted.
Follow the instructions on the screen and you should be fine.
Posted on May 09, 2009
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
I have samsung syncmaster sa300 20 led monitor, How to fix Not Optimum Mode Recommended Mode 1600 x 900 60 Hz analog, can not playing games
hi
im from iran
i have a monitor samsung sa300 18.5" that one of ics burn and i cant read his number its 8 pin and is up of the data port input. two crakter that begin by it , is at **22
please help me
Feb 09, 2012 | Computers & Internet
My monitor keeps going blank with a window that pops up saying "Not optimum mode. Recommended mode 1280 x 1024 60Hz" then there is a question mark box. I can't get the display back, no matter...
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK ME
here's the serial : JCCQ-MAKC-KACK-6TSE-BN35
Jun 05, 2011 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Monitor 2492hm - error message: "Not Optimum Mode, Recommended Mode: 1920 X 1080 @ 60 hertz". Support from Samsung very poor - their answer is '...change to optimum frequency'. How and where do I do this -...
To term in the computer is the refresh rate of the monitor. Depending on the operating system it is done a couple different ways.
Right mouse click on the desktop and choose properties or personalize (depending on your OS). In windows xp click on the last tab to change the resolution. Click on apply then click on advanced, the monitor tab, to change the refresh rate.
In Vista, click on Display Settings to be able to do the above.
Jan 08, 2010 | Samsung Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
I tried both suggestions above and neither worked. 1) Hitting the monitor buttons as stated only got me a "digital" message and then the monitor went black as usual. Never got to any menu options. 2) Going into Safe Mode and changing the monitor settings or downloading/installing the correct driver didn't stick once you went back to the normal startup.
I didn't have another monitor handy to swap out so I had to be a little more creative. The only solution that worked for me is re-booting (F8 during startup) into the mode "Enable VGA Mode". This allowed me to go into the normal desktop with a screen resolution of 800x600. I went online, found the driver, downloaded it to the desktop. Deleted the video driver (Device Manager), installed the downloaded version, rebooted and....no problems.
I have Windows XP. Hope I've helped someone today. :)
Mar 27, 2008 | Samsung SyncMaster 913N 19" LCD Monitor
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Samsung syncmaster 910t won't display
i have a solution try to check all capacitors in power supply section then replace it. ^_^
Sep 09, 2007 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
