Question about Netflix
HDCP unauthodirized content - Netflix
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Netflix Master
  • 825 Answers
Here there is a solution
https://contactus.netflix.com/contactus?locale=en-PS
Posted on Oct 13, 2013
Why after choosing a show a message comes up on the screen "HDCP unauthorized content"
To resolve the issue "HDCP Unauthorized. Content Disabled" on your Roku, follow the steps below. If a purple screen appears on your TV showing "HDCP Unauthorized. Content Disabled", it's usually caused by a loose HDMI connector, or is caused by a problematic HDMI cable
Mar 18, 2018 | Televison & Video
Roku displaying HDCP unauthorised. Content disabled. How do you fix this so you can see the picture.
If a purple screen appears on your TV showing "HDCP Unauthorized. Content Disabled", it's usually caused by a loose HDMI connector, or is caused by a problematic HDMI cable.
Dec 25, 2017 | Roku Televison & Video
I keep getting a message: HDCP unuauthorised. Content disabled. Across the screen.
Internet disable on cable box or televisio what are you using specify please
Nov 18, 2017 | Televison & Video
SOMEPROGRAMS WILL NOT PLAY, ONLY AUDIO. iT SHOWS "HDCP UN AUTHORIZED, CONTENT DISABLED"
HDCP High-bandwidth Digital Content Protection, requires uninterrupted transmission through your HDMI or DVI lead. It is to ensure you don't try to intercept copyrighted material and copy it before it reaches your TV. Check your leads are correctly fitted and are good quality.
Apr 15, 2016 | Televison & Video
What does 'this tv dose not support this programs content. Replace HDMI with component cables to view' mean?
The message has appeared because the TV can not display the hdcp signal that is now used to enable copy protection over the HDMI cable due to the TV being older than the hdcp encryption system (the hdcp is not fitted to your TV )
The two options open to you are
Replace the TV with a hdcp compliant TV
Get a component lead set up
Apr 01, 2016 | Sylvania Televison & Video
Roku 3 hdcp
Hello... I searched the internet and found this. I hope this helps...
To resolve the "HDCP unauthorized. Content disabled" issue, try these steps:
  1. If you are trying to stream 4K Ultra HD content when you see the purple screen, review the instructions for setting up your Roku player for 4K. Go to the next step if you continue to see a purple screen.
  2. On both your Roku player and your TV or AVR, unplug each end of the HDMI cable.
  3. Power off your TV and your Roku player and unplug their respective power supplies.
  4. Reconnect both ends of the HDMI cable, pushing them firmly, all the way in.
  5. Reconnect your TV and your Roku player to their power supplies and power them on.
  6. Try viewing the video again.
If the above did not resolve your issue, try these additional suggestions:
  • Try a different HDMI input on your TV.
  • Try using a different HDMI cable (less than 6 feet if available), just to make sure the cable you are currently using does not have any defects.
  • If you are using an HDMI switch or AVR, try connecting the Roku player directly to the TV.
  • Try another TV, if possible.
  • If you are using a computer monitor, try using a TV, if possible.
  • Try using different Display Settings on your Roku player. You can find these settings under Settings >Display type.
  • If this is the first time you are seeing this HDCP purple screen after setting up your Roku player, ensure that your TV and/or AVR supports HDCP. Contact your equipment manufacturer for more information.
Nov 17, 2017 | Roku 3
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
I cannot view HD channels (from freeview HD box) through my Sony str-dh810. I've narrowed the problem down to something called HDCP. When HDCP is on, I cannot view anything from my freeview box. Turning...
This piece of information should solve your problem:
High-bandwidth Digital Content Protection (HDCP) is a form of Digital Rights Management (DRM).
There is a licensing body that issues licenses for HDCP devices. Each HDCP-compliant device, like your Blu-ray player or Xbox, has a license and the ability to talk to the receiving device on the other end of the HDMI cable. The outputting device says "Hey display! Are you HDCP compliant? Here is my license, show me your license!" The display (or other HDCP compliant device) returns with "Why yes, I am legit! Here is my license!" When that process works, it happens within a thousandth of a second and you, the consumer, never even notice. You power on your Blu-ray player or DVR, it makes nice with your HDTV, and you live a happy life never knowing what HDCP even is.
if you have an older HDTV set that is not HDCP compliant then you cannot watch any HDCP compliant content on it. If you plug in your HDCP-compliant device to a non-compliant device, you'll either see a blank screen or an error message like "ERROR: NON-HDCP OUTPUT," "HDCP unauthorised," or simply "HDCP ERROR."
Short of buying a new television or giving up on your video game project the only way to deal with your HDCP compliance problem is to buy a cheap HDMI splitter that ignores HDCP requests.
Sep 25, 2017 | Sony STRDH810
How to turn off HDCP on 42PC5D
HDCP is detected and therefore automatic. You can pass video and audio via HDMI without HDCP protection IF the video and audio are not protected. If the content is protected, you will not be able to view or hear it without HDCP. So the best answer would be... by passing unprotected content to the TV. You can't just shut it off, it's part of the copy protection scheme. I hope this was helpful.
Apr 16, 2010 | LG 42PC5D Television
Netflix Logo
21 people viewed this question
Top Netflix Computers & Internet Experts
David Payne
David Payne
LP
arcada
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
