SOURCE: 2001 hyundai sonata 2.4 dohc, cylinder 3 misfire code
tried testing the igniter also i would look into the injector, that will cause a single cylinder misfire and probably is your problem?misfires are not noticeable at higher speeds, which im sure you know but i would go that route, could have a pinched injector or a stuck one. one easy way to test is swap 3rd injector with another and see if that one starts misfiring instead, another rought is to get a cheap auto stethoscope and put it to each injector to hear if its opening and closing, compare with others. good luck.
SOURCE: Entering a 2003 Hyundai Tiburon with no remote.
I belive all you have to do is put the key in the ignition and turn it counter clockwise. Hopefully that works for you.
SOURCE: 2003 HYUNDAI TIBURON bcm? Radio, clock, parking
More than likely that is your problem. It should be up under the dash on the drivers side somewhere but i could be wrong. here is a crappy pic of it.
