Question about Dyna-Glo Heating & Cooling
I have a dyna glo 30,000btu lp ventless wall heater. I know it needs the ingniter replaced. I have tried to light it by hand and can not. It seams like their is know gas getting thru,is this possible
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Yes you have to get the thermo couple hot in order to get the gas valve to open to ignite the main flame
You are probably trying to light the main flame and not the pilot
light
Hold the pilot light button down and put flame to the pilot light opening
You need to be very careful depending on the type of flame you are using to light with the thermocouple could get hot enough to open the main burner flame and it will ignite
I suggest replacing the igniter rather than doing the above step
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: Dyna-glo parts
skypainter, I also am having the exact problem you are. After reading what buffalo said, I removed my glass cover and knocked the pilot piece a couple of times with my screwdriver handle and so far so good. Guess it loosened up the spring. Just hope to get through the cold season.
Posted on Dec 27, 2007
SOURCE: Dyna-Glo RMC95C6 Kerosene Heater
I have uploaded the manual for all to use here.
Posted on Nov 22, 2008
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
CAN YOU TELL ME HOW TO REPLACE THE THERMOCOUPLE IN A DYNA-GLO PROPANE HEATER?
These thermocuoples are some of the finest ever made. The pilot not staying lit means you automatically want to try and change the thermocouple which is a costly one. And that will not fix the problem. The problem with these ODS pilots is they get dusty in summer. The safety device needs to be flushed to clear out the dust. I use rustbuster to gently flush out the pilot. I let it dry out and then light the pilot.
I had one I got all ready for winter today. Thanks for reminding me. I took some photos:
How it works and more HERE
Oct 25, 2011 | Dyna-Glo D-E39 (LP) Wall Mounted Panel...
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
http://www.mrheater.com/OrderParts2.aspx?catid=57
http://www.aandbsales.com/index.html
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
I have a dyna glo ventless model fp 65 30,000 btu flame doesnt burn very high
It would be ideal to take it apart and blow it out but you could try vacuuming out the grates real good.
Nov 11, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Pilotlight will not light, getting spark, but no propane.
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
164 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
