Question about Whirlpool Duet GHW9150P Front Load Washer
Replaced bellow after bad water leakage. Now, the machine turns on but just a chirping sound is heard when I hit the start button. Any suggestions?
    Master:
  • 818 Answers
Tub is not mounted properly-check it out-Cheers Denny
Posted on Oct 13, 2013
2 Suggested Answers
  • 389 Answers
SOURCE: I started the machine with water turned off, immediately hit cancel. Turned everything off and unplugged the machine, turned the water on and tried again. Now the start button just flashes but nothing
push and hold the cancel button in untill it starts to drain let it finnish draining and stop them it will start again let me know how you get on
Posted on Nov 14, 2011
I have a bunn CW series brewer. I filled the reserve with water and allowed to get hot. I then add additional water (1 glass pot) and it just starts to dispense without me hitting the "start" button. I...
Sounds like the switch is stuck in the operate position. Therefor once the machine hits temperature it just brews. Your local Bunn distributor should be able to recommend an engineer to replace the switch or supply the correct t,hope of switch if your confident enought Tom replace it yourself.
May 11, 2014 | Bunn CW 15-APS Coffee Maker
Start button take long to activate and doors leak
When you press start button the signal is sent to the main board. The leak is from a bad bellow that rubber on you door, if your door is not damage. it's not sealing with the door.
Apr 05, 2014 | LG WM-3677HW Front Load Washer / Dryer
After hitting the start button, the start light turns on. the machine doesn't start to pump water into the drum. i have checked the water supply its fine. then all the lights go out for 10 seconds. after...
Hi
Have you check the filters on the supply hose.
There can be one at the tap end and another inside the hose where hose thread is.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Washing Machines
My car wont start
I think your problem is the starter unit. In the starter unit there small 2 copper plates where the bendix hit against so that the current can go through. Replacing those 2 copper plates should solve the problem.
Jul 27, 2009 | 2005 Dodge Stratus
Frigidaire gltf1670a front door seal instalation
Open the door and remove either the outer bellows spring (newer models) or use a putty knife to scrape the glue around the bellows to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
Starting at the top, pull on the bellows firmly (close to the tub) until it comes out of the groove. Once it comes off you will see the bellows spring.
Install the new bellows starting at the top by aligning the marks (arrow on the bellows top and arrow on the tub lip). Work your way around until bellows is properly seated snug against the tub.
Here it gets tricky, it might be easier with an extra pair of hands but there's less room. Some bellows kits contain spacers/plugs which will help to "hold" the spring as you stretch it back in place. Work from the top down on both sides at once. Either use the spacers/plugs or have someone hold the spring in place as you work your way around.
Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet. Either re-install the outer bellows spring or re-glue the bellows to the cabinet. If this is not done you risk a water leak.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leakage. If all is well, make sure machine is still level by try to rock it diagonally from the top (if it rocks, lower the leg that is lifting). Re-install the kickplate and wash some laundry!
Feb 08, 2009 | Frigidaire GLTF1670A Front Load Washer
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
