Question about Clutch Masters FX400 Stage 4 Sprung 4-Puck Clutch Volkswagen Jetta 1.8T 6-Speed 02-06
2002 volkswagen jetta does not change gears until it has warmed up then it changes fine until it sits for a few hours
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Get a manual
Posted on Oct 13, 2013
Cooling fan stay on
Normally after a long drive it does stay on for a few mins..... After you car has been parked for a few hours.... does your cooling fan active???? if yes then there is a problem with the thermostat connected to the engine.... change it... if No then yo vehicle is fine
Jan 13, 2014 | 2002 Volkswagen Jetta TDI
My 2002 VW Jetta 1.9 will not shift out of 3rd gear. Any ideas why?
you need to have the codes retrieved out of the computer then start a diagnosis from there
Dec 03, 2012 | 2002 Volkswagen Jetta TDI
Reverse on my 97 volkswagen jetta
What about the first gear? If going easy on - change the gear box.If not-change the clutch kit.
May 13, 2010 | 1997 Volkswagen Jetta
2002 Volks. Jetta - digital display for odometer, clock, gears
Mine went blank after condensation inside windshield dripped behind the dash (sunroof drain problem). After a few months, in really dry winter weather, digital display time, gears, odometer came back. I assume water inside dash just needed time to evaporate. Sure beats $1000 to replace unit inside dash!
Aug 26, 2009 | 2002 Volkswagen Jetta TDI
2002 Jetta Wont start if its turned off for less than 30 minutes
starter is going bad will work when cool but not after engine has warmed up heat from engine is impairing operation of starter replace the starter and it should cure this
Aug 18, 2009 | 2003 Volkswagen Jetta TDI
2002 jetta TDI- I try to accelerate up a hill and no power
Count the shifts. It sounds like you are going into overdrive and staying there. Overdrive is too long legged to pull most hills unless you are really flying.. good luck
Jul 12, 2009 | 2002 Volkswagen Jetta TDI
High rpms at start, stuck in gear
You have a sticking spool in the valve body of trans or, low trans fluid. The fluid you can take care of. The trans shouldb e taken to shop for confirmation its the valve body and repair.Good luck.
Jun 13, 2009 | 2002 Volkswagen Jetta TDI
Engine shakes and hesitate when started until it idles down
Sounds like its missing on 1 or more cylinders. A check of the plugs and wires is in order, Could be a fouled plug or a loose/bad sparkplug wire. Best of luck.
Greg
May 21, 2009 | 2002 Volkswagen Jetta TDI
2001 tdi transmission wont go in gear until car is warmed up
if this is an automatic they are known for having many issues. It will require an inspection to diagnose the cause. If its a manual you probably need to change the fluid either way an inspection by a transmission shop should be done
Dec 16, 2008 | 2001 Volkswagen Jetta TDI
Clutch Masters FX400 Stage 4 Sprung 4-Puck Clutch Volkswagen Jetta 1.8T 6-Speed 02-06 Logo
55 people viewed this question
Top Clutch Masters Computers & Internet Experts
Mike
Timllfixit
David Payne
David Payne
Are you a Clutch Masters Computer and Internet Expert? Answer questions, earn points and help others
