Question about Rug Doctor 95730 MP-C2D Mighty Pro Carpet Cleaning Machine
Replace motor motor that moves the brushes is bad, where do i find it?
    Sergeant:
    Champion:
  • Rug Doctor Expert
  • 357 Answers
Your local vacuum repair shop
Posted on Oct 21, 2013
New bag indicator will not reset causing bare floor mode not to work at all and mode 2 not to vacuum dirt properly
Your top motor (suction motor) isn't running. Your vacuum has two motors in it. The top motor is the suction motor that runs on the first switch position and the bottom motor (brush motor) turns on with the second possition.
It could be the switch.If it isn't the switch, the only other thing it could be is the motor itself.
To check the switch, unplug the vacuum and then take the three screws out of the back of the handle. If you are comfortable with electricity, jump the black wire and the blue wire togeather and plug the vacuum into a electrical outlet. If the motor dosen't run, the problem is with the motor. If the motor runs, the switch is bad and needs to be replaced. You can get one at most any vacuum shop.
The motor could be bad or the carbon brushes can be stuck with dust. This is more involved and I recomend taking the vacuum to a vac shop that works on the "old" Electrolux vacuums. The new name for the "old" Electrolux is now Aerus Lux but you would probably get it repaired less expensively at another vacuum shop.
If you want to go into the motor housing you'll have to take the big screw out of the back of the handle and pull up on the handle to remove it. Next, remove the four screws holding the top half (motor housing) of the vacuum. Two screws on the back and two screws to the front inside of the bag housing. You'll need a long #2 phillips screw driver. Then pull up on the bag housing with a side to side motion.
With the housing removed, you will see the motor and can lift it out.
Check for any bad winding. You can smell them to check if you can't tell by looking at them. If they are burned, you will need to replace the motor.
To check the brushes, you will need a 5/16th" socket to remove the two bolts on the top of the motor and lift the top bracket with the carbon brushes off and see if the brushes move freely. If not moving or not long enough to touch the top part of the motor with the copper bars (the comutator) it would be best to replace the motor.
To reassemble the vac just reverse.
This is a long and difficult prosedure and I reccomend that you take the vacuum to a repair shop that works on the Electrolux.
Feb 09, 2014 | Electrolux Vacuums
Belt not moving
There are actually two belts on the Dyson DC07. The one belt that you can physically see, and a second belt that connects the clutch assembly to the motor shaft. If you're able to spin the one belt that's attached to the brushes, but the vacuum is not spinning the brush, this can really only be one of two problems. Either the rear belt that connects the clutch to the motor shaft has fallen off, which would prevent it from spinning, or the clutch assembly itself maybe bad. Usually when the clutch goes bad however it will make a terrible grinding noise first.
Here's a video on how you can access your clutch, and inspect the rear belt. Either way you'll need to take it apart to diagnosis it.
Hope this helps you:
Thank you,
Chris J.
GoVacuum
Apr 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC18 brush beater bar intermittent failure problem.
Take it in to be serviced. It could be a dead motor to bad connection. 5yr warranty will leave you paying nothing. Best Buy or local authorized service center can do it.
Nov 03, 2008 | Dyson DC18 all floors Bagless Upright...
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Deluxe windtunnel by hoover
Check for a clog in the hose or the dirt inlet by the brush roll. When there is a blockage, the thermo protector will shut the motor off to protect it. That protector could be bad, or a problem with the motor. Is the brush roll turning freely and or is it froze up and won't move.
May 25, 2008 | Hoover Windtunnel Deluxe U54219RM Vacuum
Sparks from motor when turned on
there's a short circuit on the motor armature.. needs replacement but it can be repaired depending on the problem.
Apr 15, 2008 | Vacuums
Hoover Windtunnel
Sounds like you have a bad brush roll(48414115), take it out and see the the ends turn freely or not, if not, then replace it. Also check the the slots that the brush roll sits in to make sure they haven't melted. I am assuming that the motor is running, if not, then it may have froze up.
Feb 28, 2008 | Hoover U5753-900 WindTunnel Bagless...
Rug Doctor 95730 MP-C2D Mighty Pro Carpet Cleaning Machine Logo
180 people viewed this question
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
