Question about Logitech Televison & Video
My Time Warner digital remote is often telling me that channels are not available even though I had just left it. It prompts me to try again, then it changes.
    New Friend:
    Problem Solver:
  • 6 Answers
You need to buy a universal remote
Posted on Oct 13, 2013
  • 54 Answers
SOURCE: TV DOES NOT ALLOW CURRENT REMOTE TO SEE ALL CHANNELS USING SCAN
Try using the guide to guide you threw this.
Posted on Jan 12, 2009
  • 20 Answers
SOURCE: remote codes for dynex tv time warner remote
time warner has only one code and it is 400
Posted on Nov 26, 2009
  • 142 Answers
SOURCE: My remote control will not turn on/off, change
the inner board might be burnt,i would go get a universal remote at walmart
Posted on Jan 08, 2010
SOURCE: Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Posted on Jun 19, 2010
willdan22
SOURCE: my time warner remote won't stop blinking. The
REPLACE YOUR BATTERIES AND PROBLEM SOLVED. It has nothing to do with contacts or fluid spills.
Posted on Feb 28, 2012
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Need to unlock the channel control on new Time Warner RC122 remotes to be able to change TV channel. Function is not even mentioned in their manual & TW on-line support was no help.
They are made for TW boxes only to control their TVs. I do not believe the option you request is available. use the original remote for the TVs to change the channels on the TVs.
Oct 13, 2013 | Televison & Video
Whats the code in the menu to turn on HD channels?
First the televsion programming is made available from the establsihed structure. For example, time warner cable estblsihment makes the resources available once established. Second, dish network would make programming telecast channel signals available once establsihed also. Ascertain the televsion program establsihment to enquire details that makes channel display achievble. For example, registing details from time warner cable would evaluate to establish structures from where reception is attainable. Either as code prorgams or remote control preprgammed that least requires the use from establsihing setups. Conact a television programming establsihment to evaluate the devices at the location to provide a requestion professional establsiment to attain user experineces.
Feb 19, 2011 | Motorola Computers & Internet
Feb 08, 2010 | Directed 434MHZ Remote Control
How do I retune DMTech TV Freeview with DVD video please?
Please fallow bellows instruction to retune your TV.
Could you please follow that EEPROM RESET INSTRUCTION OR FIRST TME INSTALLATION.
Also please don’t forget that MENU BUTTON from your remote, it’s not the one in the middle of remote.
There are the other MENU BUTTON in left down bottom side.
Cannot access Digital TV and am asked for a Lock code Key?
If you cannot access the Digital TV option then conduct an EEPROM RESET as mentioned above. If you are prompted to enter a lock code key enter three / four zeros.
Alternatively when prompted to enter the lock code key conduct a FIRST TIME INSTALLATION also mentioned above.
There are two options available. The first option is to conduct a general reset that will reset all user preferences. The second option would be to conduct an EEPROM RESET. An EEPROM RESET would reset all the internal hardware.
Instructions - Please refer to your DMTECH remote control and user manual provided
1. Turn the Television ON ? Button on front of Television / Power button on remote control.
2. Make sure that you are on Analogue television by pressing the TV/DVB-T button until you see PR and the channel number selected in the top right corner of the screen, e.g. PR 1.
3. You must then Press the button labelled Display until a window titled INFORMATION is displayed on the screen.
4. Only when the window titled Information is present can you continue by pressing the digit (1) twice and then pressing the button titled LINE. If you make a mistake then press Display again to remove the window titled INFORMATION and repeat the process. (Display - 1 1 - Line)
5. Once you have successfully completed step four you will notice that a menu appears on the left of the screen. You can then select which option you want, either RESET or an EEPROM RESET using the arrow keys. To execute an instruction please use the RIGHT ARROW KEY and not the ENTER button.
Make sure you have properly conducted a FIRST TIME INSTALLATION and an AUTOMATIC SEARCH. If having done this you can try conducting a manual search in an attempt to force / lock the channel.
This will erase the DVBT tuner memory and reset the interface card. This may resolve poor channel reception, the inability to store channels or even receive certain channels.
1. Turn the Television ON and select digital television by pressing the button labelled TV / DVB-T located under the power button on the remote control.
2. On the remote control locate and press the button labelled Menu, found at the extreme bottom left of the remote control.
3. A Menu should now appear displaying options. Scroll down and select the option labelled SETTINGS using the ARROW KEYS and the enter key located in the middle of the remote control. On the next menu you must select INSTALLATION to move on to the next menu.
4. On this last menu scroll down to the last option labelled FIRST TIME INSTALLATION and select it pressing the enter key. You will then be prompted to delete all channels, using the left arrow key to select yes and press enter to execute. The television will reset and prompt you to commence an AUTO SEARCH. Follow these instructions to tune in channels.picture
Digital Television requires much more from existing aerial systems. Having more than one digital TV may reduce signal quality and strength depending on how the aerial system is set up. It is therefore recommended that if you decide to use more than one digital television you use a booster and or at least make sure you are using a digital ready aerial. Using an existing Aerial that is split may reduce signal strength depending on how many times it is split. Please see the diagram below. The best solution when using an existing aerial is to purchase a booster device. Aerial Splitting - Why a booster is recommended. A booster is used to apply a small current that boosts the existing signal. A booster can be purchased from all main TV/HI-FI - consumer electronic product retailers.
Jan 16, 2010 | Televison & Video
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Jun 21, 2009 | Olevia LT27HVX 27 in. LCD Television
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Televison & Video Logo
37 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
