Question about Pool & Spa
6 of the 8 jets work. 1 of the jets seems to pull water and the other doesn't do anything. What is the problem and how do I fix it?
  • 372 Answers
There is actually a removable jet about a foot back up behind the inlet. It has become clogged. You have to remove the "eyeball" and get back in there to remove it. They come in a couple different varieties , one uses a 13/16" socket (try that first as the others are specialty tools), another uses a tool with two pins sticking straight out, and some other odd ones. Its usually a pretty quick fix.
Posted on Oct 13, 2013
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
I have a pw50 it starts fine and runs fine but doesn't seem like it has any power it barely pulls itself when I run my nitro fuel from my rc car through it it does a lot better but still not very good...
Its probably getting too much or too little fuel or air. if the intake filter and passage are clean, then you might wanna get a kit to rebuild the carb. There's a little jet that allows a certain amount of fuel in and the arm that holds it can bend over time making lack accel during rev. when you pull it apart it looks kind of like a mini metal pencil generally with a rubber tip. you need to the kit to fix it, but sometimes old gasket will come apart.
Jul 23, 2012 | Cars & Trucks
I shut off my pump yesterday and water shot out of the skimmer. when i turned the pump on it wouldn't work, the pump basket has water in it but it isn't pumping anything, no water coming out of...
I suspect you had air trapped in the filter. When the pump shut down, the compressed air in the filter pushed back, turned the pump backwards, and unscrewed the impeller off the motor shaft. This particular pump doesn't use an impeller screw which prevents this from happening. You will have to pull the pump apart to see if this is the cause. I have seen this happen many times.
Sep 15, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My polaris 280 moves around just fine and the sweeper hose is functioning properly. only issue is that it's not sucking anything up in the bag.
This can be caused by either by minimal or no water being delivered by the vacuum jets or something plugging the path to the bag. I assume you have checked the path to the bag so it is probably the first cause. The best way to check this is to turn the pump on while the cleaner is in the pool, pull the cleaner to the side of the pool, pinch off the hose just before the backup device and lift the cleaner onto the deck. Some water should be coming out of the rear jet and the tail. If you remove the bag and look down through the cleaner you should see the two jets that shoot water up. If you stand back and unpinch the hose and the water doesn't come up way above where the top of the bag would be then either you have plugged jets or the hoses inside the cleaner are disconnected. I suggest the latter because if the jets were plugged I would expect the jet that turns the wheels would be plugged also. If you don't feel competent taking it apart then bring it to Leslies Pool Supplies and they usually can open it up while you watch and repair it for the cost of parts. By watching them you may learn enough to be able to do it yourself the next time. I hope this helps.
Sep 14, 2011 | Polaris 280 In - Ground Pool Cleaner with...
I have a polaris 380. I have replaced the belts and several of the bearings. The wheels all turn at the same time when you spin one of them, however when it is in the pool and I check the RPM it...
If all the belts, bearings, shafts, etc are in order and the wheels don't turn then the turbine is not providing power to the system. This turbine is under a cover inside the cleaner. Remove the cover to inspect it (look for any mechanical problems). You can also connect water pressure to it at this time to see if the jet that turns it will make the turbine turn. If the turbine is being hit by a jet of water it should turn if the friction in the belts, bearings, shafts, etc. is not too high.
Jun 23, 2011 | Polaris 380 In Ground Pool Cleaner
Hi...my Maytag Jet Clean doesn't seem to be actually cleaning anything. Especially the glasses and crystal. They are coming out with a sort of white film on them....lip prints still in place...still...
The upper spray arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Also, make sure the water temperature is 140 degrees.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Maytag Dishwashers
The unit goes through its cycles but the top rack is not getting clean. The bottom spray wheel works, the middle and top spray arms are getting water but it seems not enough to make them rotate. The pump...
The problem is likely to be that the jets in the rotor arm are blocked.
To check this, remove the arm (it is easy to do, as it is intended for the user to do this) and clean out all the holes. Try running water from you tap through the holes (backward flow) to remove anything that is too large to pass through the jets.
Sep 26, 2010 | Dishwashers
Kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Sep 29, 2009 | Garden
HP 2800 inkjet magenta printhead/cartridge striping
I had the same issue with this printer. What worked for me was replacing the printhead for each color having the issue. In my case all of the printheads went bad at around the same time. Replacing all of them made the printer perform like new. Here is the part number for the magenta print head: HP C4812A.
Mar 12, 2009 | HP Business InkJet 2800 Printer
Phaser8560 mfp cyan jets clogged
Not really, The print head has most likely failed and in need of replacement.
That machine comes with a 1 year on site warranty. If its less than a year old, call Xerox, they will repair it on site.
Oct 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Pool & Spa Logo
27 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
