Question about Radio Communications
Does the battery need to be charged to enter passcode to alarm system
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Depends on the model, but mostly yes.
Posted on Oct 13, 2013
How do i reset the alarm on a 2002 py cruiser
when using key it like house alarm you have a few seconds to enter passcode to reset same with car you have a few seconds to enter and put key in ignition and turn on this resets alarm
Sep 11, 2016 | 2002 Chrysler PT Cruiser
How do you reset the alarm system or deactivate it on 2005 Hyundai Elantra
put key in ignition and turn vehicle on [dont have to start it ] this resets the alarm if your using key to enter vehicle it like a house alarm you have a few seconds to enter passcode the key to on is passcode it resets it
Aug 29, 2016 | 2005 Hyundai Elantra
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
I have a alarm system honeywell I dont have the passcode. I wanted to use it. the model # is I think m6950 or k5108 and has another number lynxr/lynxr24/lynxr I don't know which is the model # and i want...
you can completely down power the system, battery and AC transformer, wait a few seconds then power it back up. once powered up, press and hold both * and # buttons until "installer code" appears on the screen. Write down the installer code as is appears one digit at a time. then press *99 to exit programming. Once the systems finishes resetting, enter the installer code then 802 and the new code you wish to use. Keystrokes need to be quick, too much time between keystrokes will abort the change. Once entered correctly, a single beep should follow the last digit of the new code.
Feb 04, 2018 | Home Security
I have the home security system with four cameras and DVR. It is called the 4CH Real Time DVR. The current to the unit went out and when it came back on, it is asking for a passcode to search and...
I'm not sure if this will help you, but I'd give it a shot. I would enter zeros for the password.
It is takes 4 digits, I would enter 4 zeros. It it takes 5 digits, I would enter 5 zeros, etc.
You may also try a sequence of 1234 or 12345 etc.
These will usually be a default password for many alarm systems. Meaning that if no password
was ever set up, this is what would often work.
Give it a shot,
Good Luck,
Mark
Jan 16, 2011 | Samsung Audio Players & Recorders
Have a Bosch D2212B alarm system... came with the house. I put a battery in it and it beeps, but I need to program in a personal password. How do that?
This is from the manual:
This feature lets you change your personal passcode at any time, without
assistance from your alarm company. It is recommended that you write
down your old passcode and the new one before you begin.
1. Make sure your system is off (On light is off).
2. Press the [5] key. The OK tone sounds and the display changes
to:
3. Enter your current passcode. The Part light begins to flash and
the display shows your user number. In this example, the user
number is 4:
4. Entered a new passcode with the same number of digits as your
old passcode. If the error tone sounds, go back to step 1 and try a
different new passcode.
5. Enter your new passcode again. The OK tone sounds and the
system leaves the change passcode mode. If the error tone
sounds, start over.
Here is a link to download the manual.
http://www.minutemansecurity.com/mss/images/stories/userManualPDFs/bosch_2112&2212_userManual.pdf
Dec 14, 2010 | Event Radionics K2015a Alarm Event Manager...
I have a bosch 7212 alarm system. I need to know how to delete a code as well as add a nesw code.
If you can connect that is the easy part, if not:
1. Enter CMD 56
2. Enter passcode and press ENT
3. Enter the user number and press ENT
4. Enter
5. Enter
6. Enter the new user's passcode
7. Re-enter passcode
I am guessing step 2 would be the master or installer code...but that is just a guess
Sep 30, 2010 | Computers & Internet
The system battery was low and I replaced it. The system status continues to say that the battery is low.
The new battery may not be fully charges, need to wait a while.
Also try this enter your code + off, again enter your code + off.
If this dosen't work, remove your battery and power down your system.
Wait about 30 seconds, plig in your battery first and then power up your alarm system. You may have to adjust the time.
Let me know.
Salvo
Oct 29, 2009 | GE Security Simon 3 Wireless Home Security...
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
