Question about Sub-Zero 690 Side by Side Refrigerator
Where is the fan on the freezer side that cools the fridge on sub zero 690
  • Sub-Zero Master
  • 842 Answers
The freezer section has its own fan and the fridge has its own fan motor. The two systems are separate from each other and does not share air. The Fan in the freezer is located behind the ice maker in the freezer section.
I hope this helps.
Posted on Oct 15, 2013
  • 8 more comments
  • raj athwal
    raj athwal Oct 16, 2013
    I knew it is seperate system but some one said fan must have ice that is the reason sign comes vacume the condenser...........thank you very much but if you can help me why it keep on flashing vacume condenser. thank u.
  • Gere knutson Oct 16, 2013
    The service light comes on for various reasons could mean the following: runs too much, doors not closing properly, dirty condenser, temps are not met in a period of time. Also, because to two different systems are you sure it has anything to due with the freezer?
    I would guess this has a lot more to due with the fridge section over the freezer. What are the temps in both sections? Do you have ice that has formed on the back wall of the fridge section? Need more information, do you have any fault codes? Let me know please.
  • raj athwal
    raj athwal Oct 17, 2013
    there is no ice build up inside of both side freezer temp. is 0 & fridge is 37 . You think it can be seal on the door............thank you
  • Gere knutson Oct 17, 2013
    Hi again,
    I need more information on this unit to help you more. I need temps, so you will need a pap rand pen to write down four numbers. ( r, re, f, fe) these are the numbers I need. Open refer door, push cooler button and hold it, while holding it push and release the power on/off button. The display will show you these numbers, use the coolers button to change the display four I need all four numbers. When done, after a couple of minutes, this display will return to normal. Please get back to me and with this I can tell you what has happened to the unit.
    Thanks Gere
  • raj athwal
    raj athwal Oct 26, 2013
    what ever you told me I did hold the coider button & press on /off the sign come(off vacume condenser servise)this sign comes I have to see it with flash light because the bulb is off on the top part of the panel. Could you help me now.......than you
  • raj athwal
    some one suggested I could wash with hot water spray bottle .The condenser will be very nicely cleaned .
  • Gere knutson Oct 26, 2013
    Hi, sounds like the issue your having is beyond a simple reset or a part change. You will need to have a certified person check this because I suspect you have a sealed system issue and with this issue would cause the service light to come on and not clear. Subzero customer service number is (800) 222-7820. I know this is not what you wanted to hear but without physically looking at this unit, instructing someone beyond this point is or can be risky. Sorry I could not direct you in a happy conclusion.
  • raj athwal
    could you please tell me can I wash condenser some one suggested other I said I can't see that part of the electric panel because top light bulb is not working that is the reason I have to see with flash light ( it was flashing vacum condense service)thank you for you time.if you could answer this
  • raj athwal
    raj athwal Oct 27, 2013
    If it is something else wrong with fridge then it should not flash vacume condenser after 24hrs. It should always be flashing SERVICE.Could you please help
3 Suggested Answers
  • 7 Answers
SOURCE: sub zero 690-temp
The 690 does not have a 'door open' warning bell. Too much stuff in the wrong places can make door not close the last tiny amount. Over many hours the temp will go up. Does the same if freezer door left open. Check this before do major service.
Posted on Jan 19, 2009
  • 7 Answers
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Posted on Dec 11, 2009
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero side by side freezer working fine frig set to 38 and is up to 50 and will not cool anything I can do?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
diane.white@subzero.com
Sep 18, 2008 | Sub-Zero 690 Side by Side Refrigerator
Fridge side not cooling, Freezer side is....
(After trying FixYa and paying for the premium service -- during which error codes were not even discussed) I called a service tech. Turns out it was the fan above the fridge side (which explains why the freezer was still working fine) that was "humming" but not always spinning. A quck swap of the fan and we were back in business.
FYI -- The SubZero tech said it was very uncommon for the fans to go bad.
Feb 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
353 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
