When I connect my computer to my TV via HDMI, the screen is too zoomed in and the colors look horrible (blurry, wrong hues, etc), but it works perfectly with a VGA connection on 1920x1080 mode.
    New Friend:
    Problem Solver:
  • 6 Answers
Check the dpi settings on your computer
Posted on Oct 13, 2013
Testimonial: "I should mention that my computer works very good when it is connected to my other TV, a 1080P samsung smart tv,through HDMI. The fact that it doesn't work on my JVC tv leads me to think that it is a problem with the television."
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Posted on Dec 08, 2008
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
ripleymojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
SOURCE: Insignia 22'' LED HDTV screen resolution problem with VGA
I think this stems from the fact there is no VGA mode designation (not plug and play) however there are VGA H&V settings that may be overidden from autodect mode under ADVANCED in teh menu. What sux is that it isnt stored and must e reset when input changes. FIRMWARE UPDATE PLEASE INSIGNIA!
Posted on May 22, 2010
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
HDMI PROBLEMS
sounds like the picture on you tv is set on fit to screen mode try under menu set picture to different setting there should be a normal setting
Mar 02, 2014 | Toshiba 42AV500U 42 in. LCD HDTV
Pc reads tv through hdmi but tv says no signal still what do i need to do?
The TV reads the PC via the HDMI out from the computer. You must make a direct connection from the PC to the HDMI input on the TV with a proper HDMI cable. Once that is established, you need to be certain what HDMI Channel is represented on the TV, HDMI #1, 2 or 3? Etc. Best you turn on the PC AFTER all connections are made and the TV is in full operation and the channel HDMI 1,2,or 3 etc. are on. Now turn on the PC and see if you get a connection. You may have a picture if you are streaming a video, and NO sound. If so, reset the Audio by clicking on the speaker icon at the lower right of your computer screen, and in the Volume Control Options select the output you wish to use.
Jan 05, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
When connected via HDMI, get picture filled with wrong colors - oranges, reds, blues; when connected via Component or Composite - works fine
You can ofter setup HDMI on your devices in different modes, for example my old tv had options that i could change RGB and other settings for hdmi. try looking in the settings of the DVD-player and see if you have hdmi options
May 03, 2011 | Philips DVP3982 DVD Player
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
Bush iD HDMI 37inch tv hdmi problem
turn laptop on when the hdmi cable is in it not after laptop is on
Sep 03, 2009 | Televison & Video
XBOX Live plays back with pink hue
*YOU DO NOT NEED TO SWITCH TO STANDARD DEFINITION*
To view the videos via HDMI, you need to switch the HDMI Color Space setting to "RGB". To do this go through:
My Xbox > System Settings > Console Settings > Display > HDMI Color Space > and from there select RGB
I had this same issue when watching movies from a USB flash drive and this worked perfect, so I hope this helps those of you who love your HDMI as much as I do.
Aug 17, 2009 | Microsoft Xbox 360 Console
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
