Question about LG WD-1080FD Front Load Washer
WM2301H LG washer error code d1
How do I find serial number in LG washer WT 1101CW
OK, On my prior post for your LG I answered this question (One of four) you posted!
Jun 28, 2014 | LG WM2301H Washer
LG WM2301H ball bearings issues
See my answer on your prior post!
Apr 16, 2014 | LG WM2301H Washer
Lg wm2301h turn on by itself
This is something that you NEED to call LG on and have them fix it! Because I can tell you it is a fault in your computer board. Cost $200-700 dollars!!!! Yeah right! If you need to replace the Brain of any unit you might as well get another unit. It was faulty from day One!!!!
Apr 06, 2014 | LG WM2301H Washer
Lg wm2301h keeps saying oe
problem with water not draining..kindly check drain motor..
Feb 05, 2014 | LG WM2301H Washer
WONT PUMP WATER OUT
And you want it to WORK!? Gosh...I guess you Need to replace it! But first you need to order one! Go Here:https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=LG+WASHER+PUMP
To Replace the Pump watch this
Jan 07, 2014 | LG WM2301H Washer
Error code te
Jeff I Hope since 2013 you still don't have that Code. If you unplugged it (for 30 minutes) then power it up. It should work
Nov 25, 2013 | LG WM2301H Washer
LG WD-1080FD Front Load Washer Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
