Question about Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 side by side ,I have clean the condenser but vacume condenser keep on flashing .Turn the fridge off from the circut then on but same words are flasing after 12 hrs or so.Fridge temprature is on 37 & freezer on 00.What could be wrong.both side are running fine.Could you please some one help me with this problem.Thaks
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
MOST LIKELY FRIDGE SECTION IS LOW ON FREON! "VACUUM CONDENSER" WILL COME ON IF COMPRESSOR RUNS MORE THAN IT SHOULD BE. COMMON THING IS LEAKING EVAPORATOR COILS IN FRESH FOOD SECTION. CHECK MY VIDEO, I HOPE IT HELPS.
Posted on Apr 19, 2014
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
SOURCE: sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Posted on Oct 08, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Posted on Mar 27, 2009
  • 396 Answers
SOURCE: cleaned condenser on sub sero 680f and now fridge is running high
Check to see if the condensor fan (underneath the refrigerator) and the evaporator fan (behind a panel in the freezer) are both running. If one of these is not running, the refrigerator will not have its full efficiency.
Posted on Oct 18, 2009
  • 12173 Answers
SOURCE: sub zero 532. freezer works fine --0 degrees.
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Posted on Jun 28, 2010
Testimonial: "thanks for the help - I will check all your suggestions "
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Feb 21, 2015 | Sub-Zero 690 Side by Side Refrigerator
Is it possible to clean the condenser with low velocity air compresser . My sub zero 690 side by side fridge flashing VACUME CONDENSER SERVICE.
Yes but this will create a dusting nightmare for the rest of the house. By just cleaning the condenser is not enough for the computer has no knowledge of said act. You must rest the computer after cleaning, your model has a picture of a bell on the panel of the control. Push and hold that bell for 10 seconds, you should hear a beep and the service light will disappear. If this returns, this means either the condenser is dirty or the computer has detected that it takes too long to reach your desired temp. But reset first, less work and see what happens.
Good Luck
Nov 02, 2013 | Sub-Zero 690 Side by Side Refrigerator
It starts flashing VACUME CONDENSER after 24 hrs on my sub zero 690 side by side fridge .I cleaned the condenser but some one suggested I can wash with hot water spray bottle (I did not tried).If there is...
"Vacuum Condenser" light on this refrigerator will appear if you have any kind of issues - some of their models would have "Service" light instead of Vacuum Condenser. As My expirience shows Most likely Your Fresh food section is low on refrigerant - Evaporator might leak freon - so what we would have in this case - compressor runs for longer time then suppose to - as a result "Vacuum Condenser" or (some models) "Service" appears. Another sigh of low freon pressure people would notice ice build up on the back wall of the refrigerator section on the left side on the middle. I post video on my YouTube chanel, so u can check how to fix it properly.
Oct 27, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 side by side the vacume the condenser light keep on flashing after 12 hrs or so but the condenser is clean it could be my both door are not flushed together .Fridge side door is little out may...
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Oct 18, 2013 | Sub-Zero 690 Side by Side Refrigerator
Another question by me
Most likely that light is caused by a refrigerant leak somewhere in the fridge system. Most likely the fridge evaporator, but you would need a leak detector to confirm this. It could also be that the fan to cool the compressors is not running all the time, or that the compressor itself is weak. Do you have any error codes? Is there a ball of ice forming on the back wall of the fridge section on the left side towards about halfway down from the top? what is build date on the serial tag, located on the frame of the fridge inside the freezer door at the top. Good luck, hope this helps.
Oct 16, 2013 | Cell Phones
Cleaned the condenser on model 690 sub zero side by side after 12 hour or so it says vacume the condenser......thanks
Is this still an issue as this post is a month old? Was the computer cleared after cleaning? If not, hold the (bell) button for 10 seconds and you should heard a beep. This will clear the computer (the fault from the screen). If it returns you may have a cooling issue only the computer noticed, you made need a service tech to look at this. But only if this continues.
I hope this helps.
Sep 16, 2013 | Sub-Zero 690 Side by Side Refrigerator
My fridge of 9 years has service ec flahing on it. What does it mean
the service flashing light just means that something is not operating correctly. Most common thing would be that the condenser needs cleaning. it is behind the grill that is removable. Vacuum the coils and turn the unit off for one minute and then turn it back on to reset the service light.
Mar 20, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
115 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
