How to fix leaking washing machine - Washing Machines
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Change the seals, gaskets, o-rings...
Posted on Oct 13, 2013
Fix error code E01 on smeg wd1 16ba washing machine
Possible leak is what that code means. Check for leaks.
Nov 14, 2017 | Smeg Washing Machines
Why is my washing machine leaking? How do I fix it?
You can try looking up your problem on You Tube.They have a lot of instructional videos on how to fix items yourself.I installed my water heater this way!
Aug 24, 2014 | Washing Machines
Whirlpool LSR8010PQ0 motor hums and leaks water
Somethnig is wrong with your transmission. Since it is leaking, the seals are broken or damaged. The water leaked in your transmission. The problem with Whirlpool washing machines, the motor is directly coupled with the transmission. There is a high probability that the leaking water corroded the transmission, thereby freezing it. Your best bet is to have the transmission and the water leak fixed. Do not run the washing machine till you have this fixed, otherwise, you face the chance of losing your motor.
Jun 22, 2014 | Whirlpool LSR7333 Top Load Washer
My whirlpool washer is leaking from the front center. Happens during spin cycle I think.
Hello.
If your washing machine is leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
    • 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
    • 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
    • 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
    • 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
    • 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
    • 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks.
Sep 03, 2011 | Whirlpool Washing Machines
Washer leaks from under the front of the machine.
If you are having a problem with your washing machine i.e leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Instructions
  1. Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
  2. Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  3. Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  4. Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  5. Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  6. Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Good luck and thank you and thanks for using fixya.
Jan 30, 2011 | KitchenAid KAWS750L Top Load Washer
Fix a new door seal on an= washing machine
Heres an old trick and recommended by certain manufacturers: You shim the latch with washers. That makes the lock close tighter and reduces leaks to a minimum. Using correct amounts of detergent also minimises leaks aroud the door as well as musty odors.
Apr 19, 2010 | Washing Machines
My roper wash machine is leaking. is it worth
check when it's leaking during the cycle.
If the fill hose has become unhooked from the outer drum of the machine, it'll just dump water all over the floor... it'll leak out of the case of the machine, but it's an easy fix... you simply open the machine, reinstall the hose into the drum or you may have to replace the hose...washing machines will last a good long time...it's worth the trouble to fix...let me know if you need help opening it up.
This can happen if the machine is overloaded... I had a laundromat and this happened alot because people were cheeeeep and wanted to overstuff the machine thinking they'd get a better deal...not true...dirtier clothes and broken machines....
Aug 05, 2009 | Roper RAB2121KW Top Load Washer
Leaking out of the bottom
The water drainage pipe is probably tampered. You need to replace it. Take apart the washing mashine and find the drainge pipe. If it is not tampered, some pipe is loose or broken in the washine mashine. If all this is too hard, call a repair man to fix it.
Apr 07, 2009 | Washing Machines
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
