Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Mower starter pinion gear won't stay on flywheel to start it
The mower has a 12.5 Br & Stratton engine/mod 289707 / type 1179-E1 /code 980529ZB. The starter gear won't stay up on the flywheel to start the engine. The starter just spins rapidly. I tried manually turning the pinion gear and engaging it wjith the flywheel, but as soon as I hit the starter, the gear drops back down and spins. Do I need to replace the starter? Is there a way I can fix this one?? Thanks! John
  • 82 Answers
You can actually just replace the starter bendix
Posted on May 09, 2009
1997 grand jeep cherokee wont start all the way it starts to then you hear a high pitch whine
Sounds like a starter shaft, housing or spring. Possibly a flywheel, but probably not. You might need to either tighten some starter bolts or replace the starter. If the starter bolts are tight, you don't want to tighten them anymore. That will tell you if your starter is loose or just needs to be replaced.
Feb 17, 2017 | 1997 Jeep Grand Cherokee
Want turn over but but has power to starter
If you mean "Won't turn over but has power to starter" instead "Want turn over but but has power to starter" than change the starter. My guess, the pinion that shoots out the gear to turn the flywheel to achieve crank is broken and spins uselessly. When you turn the key you hear it spin but it can not turn the flywheel to start the vehicle. The other option is less likely but I have heard of someone trying to start a ceased engine so many times that the gear that turns the flywheel gets stripped and just spins.
Mar 23, 2014 | 1986 Chevrolet Chevy
I have a 19.5 briggs and stratton engine on a craftsman model #917.270910. The starter turns engine then the engine hangs up not turning completely. briggs ans stratton mod#461707 type#0145 E1 code #
The decompressor is a valve lifter usually on the exhaust valve, the only adjustment is to correctly set the the valve clearances, if they are too slack the lifter will not activate.
Apr 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starter motor whirls, does not engage / start engine. Battery is fully charged
The starter is actually an assembly with a motor and a solenoid. The solenoid does two things: it closes a contact to send electricity to the motor, but it also moves a gear on the motor shaft upward to engage a gear on the engine flywheel. Most likely, you will have to replace the starter assembly to fix this.
Just in case, you should also check the gear on the engine flywheel. It's where the starter pinion engages. If it's missing several teeth, you could just be in that 'dead spot'. That can temporarily be solved by turning the motor a little bit to get to a good spot - but remove the sparkplugs first! And eventually you'll end up in the dead spot again. It is a more expensive repair.
Good luck! Please rate if you find this helpful, thanks!
Jun 03, 2010 | Briggs & Stratton Garden
Starter spins but will not engage flywheel...
Check the flywheel for areas of damaged teeth also. Broken teeth on the starter drive gear may inticate damage to flywheel also.
May 20, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How many different types of starter motors are there to suit a 12 hp ride on mower
First you have to have a flywheel that will support a starter. It must have a toothed flywheel. Second, the brand of motor. Briggs & Stratton, Tucumseh, Kohler, Onan, Wisconsin, ect. Was it originally electric start? Has battery tray, key switch, ect? You will need the Serial Number, Model Number which is on the "blower housing", or the recoil start housing on the top of the motor to replace with the correct starter. You probably can find one at any small engine repair shop, maybe a lower cost used starter. But you need the information above to obtain that. Model #, Serial #, Make, ect. If this mower wasn't electric start originally, this will be a major change. Flywheel, starter, wiring, battery, switch, and the like. Not for the faint of heart. It can be done, and has been, but will be difficult. If it is a Briggs and Stratton, you should find parts easy to access. And Tecumseh. And relatively economic.
Sep 27, 2009 | Garden
Parts list required for starter and drive gear spring assembly (engages flywheel on start). Engine model 303777.
First on the shaft goes the small felt washer, if supplied, the the drive gear, the return spring, the cap washer and the circlip. Thats it.
Aug 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
825 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
