Question about Husqvarna Scandinavia 100 Sewing Machine
Pressure foot pressure control
The control knob moves and the pressure increases as the number increases BUT the setting does not hold and decreases as I sew becoming too loose
    Champion:
  • 241 Answers
The pressure foot knob had some problems. on this model. The solution was to remove the covers and the e clip that holds the knob in place. I install a belleville spring washer on the knobs shaft. This extra tension keeps the knob from turning when the sewing machine vibrates. This may be more difficult than most consumers want to attempt.
Posted on Oct 13, 2013
3 Suggested Answers
  • 1116 Answers
SOURCE: stippling for Viking emerald sewing machine
The switch in the back will lower the feed dogs.
If you need a manual - I found a PDF download by googling: viking emerald 183 manual
Posted on Feb 23, 2010
  • 5370 Answers
SOURCE: Presser foot goes up when
Try turning the presser foot pressure to a higher number. Ususally it at 4-5.
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.---------- try this and check.this should help.thanks.Helpmech.
Posted on Jun 06, 2011
How do I change tension when I'm sewing a thro for a bed and the material is thick?
You probably need to change the "presser foot pressure" if your machine has the function. It increases or decreases the amount of pressure the presser foot applies to the fabric. You can also try using a walking foot, teflon foot, or roller foot to see if it helps feed the fabric and make a more even stitch.
Mar 23, 2017 | Sewing Machines
Started sewing on my machine and after 16 inches and hitting the reverse stitch button I can hardly get it to move. I can move it manually. Have I done something wrong?
If the machine has a problem backing up it is due to the thickness of the material. Remember; as you are sewing forward the thickness increases with the added stitches. This has the effect of increasing pressure on the foot. Try to lower the pressure on the foot. Also, you are likely using a very high number of stitches per inch. To lower this number might also help.
Jan 17, 2017 | Sewing Machines
The pressed foot lifter won't hold the material, I can push it up down turn it around this is not right
Are you saying the presser foot has very light pressure on the fabric? If so, most machines have the ability to increase the pressure the presser foot applies to fabric and feed dogs. It depends on your machine's make & model where & how that pressure is adjusted. Older machines usually have a large skrew or knob at the top of the needle bar that tightens down on a big spring, thus the tighter spring increases the pressure. Newer machines sometimes have a dial usually located on the top left or side of the machine head. (Consult your owner's manual.)
http://makeitsew.biz/presser-foot-pressure
The Best Kept Secret on Your Sewing Machine Sew Daily
Parts of Sewing Machine Pressure Adjustment
Under Pressure Adjusting Presser Foot Pressure
May 25, 2016 | Sewing Machines
How do I adjust the presser foot pressure on my Janome 7100QDC
your model doesn't have this feature Janome 7100QDC Computerized Sewing Machine , it it did, there would be a knob on the top left of the machine above the presser foot which you could screw up or down to increase or decrease the pressure. Its not a feature on many machines, the presser foot bar has a big spring internally which applies the pressure and this will just adjust to suit the fabric under the foot.
Mar 01, 2015 | Janome Sewing Machines
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
How can regulate the pressure foot? BERNETTE 134DL thanks a lot
There's a white knob on top of the machine, directly over the presser foot bar. Twist to the right to increase pressure, left to decrease pressure.
May 19, 2014 | Elna Sewing Machines
Not sure about it says increase or decrease pressure
There should be a control on top of your machine that is directly over the needle OR, if you have a "door" on the left side of your machine that exposes some of the workings, then there might be a dial inside there. The pressure refers to the amount of pressure the sewing machine foot applies to the fabric. For thick fabrics, you will want to lighten that pressure. For thinner fabrics, you might want to increase that pressure. Use those controls to set the foot pressure. Try it out with a scrap to see if the pressure is to your liking. Good luck!
Mar 10, 2014 | Sewing Machines
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
Mar 22, 2012 | Brother Sewing Machines
I need to know how to change the pressure between the foot and the sewing plate. I have no problem doing regular sewing but when I try to do several layers (such as quilting) the pressure is too much and...
The rotary control on the left-hand end of the sewing arm controls the foot pressure. You shouldn't normally need to vary this, except when quilting thick materials. The control is normally set with the 'bar' in the middle of the knob straight up-and-down, but you can reduce the pressure by turning it - the markings on the head cover correspond to increasing and decreasing the foot pressure.
Aug 04, 2011 | Bernina Artista 170
There is a knob on the left side of machine, I don't know what it does or used for. The manual didn't make it to me with the machine. I figured out the threading, but the tension is too tight. I would...
The knob on the left is the Pressure Foot pressure dial. Here is what the manual says about it: " This dial regulates how hard the presser foot is pushing down on the fabric. To little pressure may cause poor feeding of the fabric, skipped stitches, or difficulty in guiding the fabric as you sew. Too much pressure may result in one layer feeding ahead of another or feed teeth or presser foot marks on the fabric. For most fabrics set the dial at 2. For thicker fabric increase the dial to 3 and for thin fabric decrease to 1." The red dial on top, the far left one, is the tension dial. Just have to play around with that til you get it like you want. Hope this helps!
Jan 12, 2011 | White Sewing 2037 Mechanical Sewing...
Husqvarna Scandinavia 100 Sewing Machine Logo
67 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
