Question about Facebook Apps
I can't play my favorite dollar table. I have over 5 mil, but can't play 2000-4000 table.
Well, get a hack and try to do something :)
Posted on Oct 13, 2013
What are the advantages of playing online poker?
There are a lot of advantages of playing poker online.
Some of the major advantages are given below:
a. Lots of games option.
b. Safe and fast.
c. More bonuses and gifts.
d. More chances of winning money.
If you want to play poker on your own device, you can easily play by registering safely in one of the most trusted online platforms of Indonesia which is Judi Bola Online Terpercaya.
Jan 05, 2016 | Games
Tip
How to Restore a Picnic Table
After several years and a being exposed to the elements, your wooden picnic table can start to look really worn out. You don't need to spend a few hundred dollars on a new one - you can restore your old one. It's a project that will be both fun to do and save you money.
Where do I start?
1. Using a mixture of bleach and water (not too strong), scrub the table really well and leave it to dry completely.
2. Check the table for structural damage; hammer in any loose nails or boards and fill in any holes with wood putty.
3.
Now you need to sand the table down. Sandpaper comes in grain s of coarse through to fine. The worse state your table is in, the coarser sand paper you will need to start with. When you are finished, clean the dust off really well.
4.
Now you can paint or wood stain the table depending on whether you prefer a more natural look or a brighter one.
5.
Leave it to dry completely before using it. Enjoy your new table!
on Aug 20, 2012 | Garden
F1 code come on after 5000 rmp only n gear.i changed oil but used cheap oil.i lost speedometer at the same time.could this b the oil or do I have different problem.please help
Place the motorcycle on its side stand.
Start the engine and let it idle.
If the malfunction indicator lamp (MIL) does not light
or blink, the system has no memory of problem data.
If the malfunction indicator blinks, note how many
times the MIL blinks, and determine the. cause of the
problem (page 5-10 through 5-49).
If you wish to read the PGM-FI memory for trouble
data, perform the following:
Tum the ignition switch OFF.
Remove the seat (page 2-2).
Short the PGM-FI system service check connector terminals
using a jumper wire.
Tum the ignition switch ON and engine stop switch
RUN.
Even
if the PGMFl
has memory
data, the MIL
does not blink
when the engine
running.
If the ECM has no self diagnosis memory data, the
MILwill illuminate, when you tum the ignition switch
ON.
If the ECM has self diagnosis memory data, the MIL
will start blinking when you tum the ignition switch
ON.
Note how many times the MIL blinks, and determine
the cause of the problem (page 5-10 through
5-49).
SELF-DIAGNOSIS RESET PROCEDURE
1.Tum the engine stop switch RUN and ignition
switch OFF.
2. Short the service check connector of the PGM-FI
system using a jumper wire.
3. Tum the ignition switch ON.
4. Remove the jumper wire from the service check
connector.
5. The MIL lights about 5 seconds.
While the indicator lights, short the service check
connector again with the jumper wire.
Self diagnosis memory data is erased, if the MIL
tum off and start blinking.
.The service check connector must be jumped while
the indicator lights. If not, the MIL will not start
blinking. Note that the self diagnosis memory data cannot be
erased if you tum off the ignition switch before the
MIL starts blinking.
If the MIL blinks 20 times, the data has not been
erased, so try again.
Nov 14, 2013 | 2005 Honda CBR 600 RR
Are the pockets on all billiard tables the same size?
On regulation tables, corner pockets are 4fl inches wide and the two side pockets are 5 inches wide. Some tables may have smaller and deeper pockets; which makes the game a little harder to play.
Jul 25, 2012 | Sport & Outdoor - Others
What can I use to decorate my living room table?
As a designer, my favorite way to decorate a living roomtable is by placing a large, bright doily over it. When the ends of the doily fall just over thesides of the table, it looks classic! Putting a medium d glass vase in thecenter with one type and color of flower in it always tops the table offperfectly.
May 29, 2012 | Furniture
How to play omaha
To start a new hand two "Blind" bets are put up or "Posted." The player immediately to the left of the player with the dealer button puts up or "posts" the small blind which is approximately half the minimum bet. The small blind for the $2/4 game is one dollar. The player to the left of the small blind posts the big blind which is equal to the minimum bet which is three dollars for this game. The rest of the players do not put up any money to start the hand. Because the button rotates around the table, each player will eventually act as the big blind, small blind and dealer. It will cost you three dollars every time the deal makes a complete rotation around the table.
The Opening
After the blinds are posted each player is dealt four cards face down with the player on the small blind receiving the first card and the player with the dealer button getting the last card. The first betting round begins with the player to the left of the big blind either putting in two dollars to "Call" the blind bet, or putting in four dollars to "raise" the big blind or folding his hand. The betting goes around the table in order until it reaches the player who posted the small blind. That player can call the bet by putting in one dollar since a dollar bet was already posted. The last person to act is the big blind. If no one has raised, the dealer will ask if they would like the option. This means the big blind has the option to raise or just "check."
The Flop
e cards are dealt and turned face up in the middle of the table. This is known as the "Flop." These are community cards used by all the players. Another betting round begins with the first active player to the left of the dealer button. The minimum bet for this round is also three dollars.
The Turn
When the betting round after the flop is completed, the dealer burns another card and turns a fourth card face up in the middle of the table. This is referred to as the "Turn." The minimum bet after the turn is now six dollars and begins again with the first active player to the left of the button.
The River
Following the betting round for the turn, the dealer will burn another card and turn a fifth and final card face up. This is called the "river," and the final betting round begins with six dollars being the minimum bet. There is usually a three or four raise maximum during all betting rounds except if the play becomes heads up with two players. Then the raises are unlimited.
The Showdown
To determine the winner, the players MUST use two of his hole cards and three cards from the "Board" to form the highest five-card hand. In some cases two players will tie which happens quite often in Omaha Hi/Lo. In that case the players will split the pot. A sixth card is never used to break a tie.
Jun 30, 2011 | Carrom Game Board Large
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
Iam having troble with the tactical mil dot range estimating. Can you help me out
are you trying to zero it, or are you trying to figure out the estimating ranges, if so can you please specify better?
1. width or height ( in inches ) x 25.4 divided by number of the mils of the target as seen in the M3A = range in meters
OR
2. height in meters X 1000 /divided by the mil size of the target = range in meters.
if you need a chart
http://www.snipersparadise.com/marksmanship/images/table.gif
Nov 24, 2009 | Centerpoint Technologies Optics
Trying to install office 2007 but keep getting error code 1606 cannot find network location %APPDATA%. What can I do to fix this?
To resolve this issue, follow these steps:
  1. Click Start, click Run, type Regedit.exe, and then click OK.
  2. Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  3. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7. For Windows XP and for Windows Server 2003, see the following table. Collapse this tableExpand this table Value name Type Value data AppData REG_EXPAND_SZ %USERPROFILE%\Application Data Cache REG_EXPAND_SZ %USERPROFILE%\Local Settings\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\Local Settings\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\Local Settings\Application Data Local Settings REG_EXPAND_SZ %USERPROFILE%\Local Settings My Pictures REG_EXPAND_SZ %USERPROFILE%\My Documents\My Pictures NetHood REG_EXPAND_SZ %USERPROFILE%\NetHood Personal REG_EXPAND_SZ %USERPROFILE%\My Documents PrintHood REG_EXPAND_SZ %USERPROFILE%\PrintHood Programs REG_EXPAND_SZ %USERPROFILE%\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\Start Menu Startup REG_EXPAND_SZ %USERPROFILE%\Start Menu\programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\TemplatesFor Windows Vista, see the following table. Collapse this tableExpand this table Value name Type Value data {374DE290-123F-4565-9164-39C4925E467B} REG_EXPAND_SZ %USERPROFILE%\Downloads AppData REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming Cache REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\AppData\Local My Pictures REG_EXPAND_SZ %USERPROFILE%\Pictures My Music REG_EXPAND_SZ %USERPROFILE%\Music My Video REG_EXPAND_SZ %USERPROFILE%\Videos NetHood REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts Personal REG_EXPAND_SZ %USERPROFILE%\PrintHood PrintHood REG_EXPAND_SZ %USERPROFILE%\Documents Programs REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name, Type, or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 3, and then press ENTER.
  6. Right-click the value that you created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
  7. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  8. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12. Collapse this tableExpand this table Value name Type Value data Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates
  9. If any Name, Type, or Value does not match the table in step 8, right-click the Value name, and then click Delete.
  10. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 8, and then press ENTER.
  11. Right-click the value that you created in step 10, click Modify, type the value in the Value data box for the Value name, and then click OK.
  12. Exit Registry Editor, and then restart the computer.
Sep 04, 2009 | Microsoft Windows Vista Home Premium with...
How to tell if your friend is gay
# 1 he has hair on his knuckles
# 2 he talks in a girlly voice
# 3 ask him !!!!!!!!!!!!!!!!!!
# 4 does he listen to girlly music alot IE.. back street boys ???
# 5 is his favorite movie mamma mia 2008
# 6 is bet middler his favorite singer
# 7 does he own a hair straightener
# 8 limp wrist sure sighn
# 9 does he play grab *** with u hmmmm he is gay straight guys dont play this game !!!!!!!!!!!!!!
# 10 the ???? is are you ??
# 11
hope this helps i got a few gay friends so here u go... nad no i am not
Dec 19, 2008 | Toys
Facebook Apps Logo
20 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
