Question about Lands Phones
89 firebird 5.7L no start... replaced fuel pump and filter still no fuel to motor relay?
  • 12 Answers
SOURCE: Fuel pump relay
Fuel pump in back in the gas tank.
Posted on Jan 30, 2009
motor1258
  • 6674 Answers
SOURCE: 89 firebird blows fuse that powers fuel pump and ecm?
That joint & where wires separate, would be a good spot to use a clamp on amp meter, if you have, or know someone who has one, then you could get reading on each one, and zero in on one(s) with most draw.
Posted on Apr 01, 2009
bluelightnin
  • 35 Answers
SOURCE: Fuel relay placement 1991 Buick LeSabre. Replaced pump & filter still won't start
Your vehicle's fuel pump relay is located on the relay center, behind the glove box, 2nd column of relays, 2nd one from the top.
Posted on May 23, 2009
SOURCE: engine will turn over but
try the emrgency cut off switch located in the trunk behind the driverside tailight.
Posted on Oct 12, 2010
SOURCE: where is fuel pump relay
where is the fuel pump located on my 1994 acura legend and how to check the relay and where is it located
Posted on Nov 06, 2010
2002 Cavalier starts then dies. Started about 1 week ago. Let sit overwrite started fine next afternoon. Ran great for several hrs. Started dying again. Replaced fuel filter, Ran great for a day. Now it...
Had a 89 cavalier did that start then die it map sensor. Also check ground wires if the become too corroded they won't start sometimes just run weird
Jan 21, 2015 | 2002 Chevrolet Cavalier
Im not getting fuel to the motor it will run with starting fluid through the intake but not on its own i cant find the fuel pump relay to check that
If it is carb. you don't have a relay because your fuel pump is mechanical mounted to the passenger front side of the engine if it is a v8, if it is fuel injection, most likely either your fuel pump is bad or something I had go wrong with mine was the hose that connects the fuel line to the pump had a tear in it. The bad thing is you will have to drop the tank to find out. If it is fuel injected, turn the key to the on position, you should hear the fuel pump buzz, if you hear that check your fuel filter. If the fuel filter don't fix it replace the pump. Hope this helps
Jun 13, 2011 | 1987 Pontiac Firebird
88 firebird doesn't get fuel, I replaced the fuel pump and did a test run and it works, I also replace the fuel pump relay, and Im still not getting fuel.
I would check the fuel pressure regulator, fuel filter, there might be a centrifugal cut-off switch. No output from the crankshaft position sensor would probly cause that. When you turn the key on you should be able to hear the pump run for a couple seconds. If not, could be a short circuit, loose connection, that sorta thing.
Jan 05, 2011 | 1988 Pontiac Firebird
Motor running in the back of an 89 gta 5.7 t.p.i.
The fuel pump is located inside the fuel tank which is in the rear of the car. It's powered by an electric motor. Check the owner's manual for location of fuses and relays. Some are located under the hood (either on the fender or firewall), others are under the dashboard (near your left foot), on the side of the dashboard (look for cover on side of dashboard with driver's door open) or even inside the glove compartment (if you have one). That sound of a motor running is normal, and may be louder if the tank is close to empty.
May 02, 2009 | 1989 Pontiac Firebird
I have a 89 pontiac firebird formula that is not getting fuel to the carb. I checked the fuel pump and it is in working order. any suggestions?
have you checked the fuel filter?? often they can get dirty and need replace which is a 20 dollar filter, you may also buy a bottle of carb cleaner to run through your vehicles gas after you get the gas running through your vehicle that is
Apr 05, 2009 | 1989 Pontiac Firebird
Fuel pump will not stop
Could be a bad fuel pump relay. Disconnet the F/P relay and see if the pump turns off. If so replace that first and come back if that does not fix everything.
Mar 30, 2009 | 1989 Pontiac Firebird
Cant locate the fuel filter for a 1989 firebird formula
It should be under the car, back by the gas tank
Mar 28, 2009 | 1989 Pontiac Firebird
99 fire bird wont start
Sounds like the fuel pump is bad. You need to test fuel pressure. I can tell you the fuel pressure spec, but what year is it 89 or 99? And what engine?
Mar 08, 2009 | 1989 Pontiac Firebird
Fuel pump
fuel pump, relay,fuse, possibly pump, fuel filter
Oct 05, 2008 | 1999 Pontiac Firebird
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
