Question about Great Plains Industries Gpi& Fuel Pump
How do u know if the fuel pump is bad. my 94 trooper hard to start, as im driving it will cut off and wont start again until the truck has cooled down.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
It could also be the sparkplugs
Posted on Oct 13, 2013
My 94 chevy pick up starts and files good but cuts out bad when put in gear and give gas
could be clogged fuel injectors or fuel filter could be plugged or your fuel pump is weak and needing replaced,what makes fuel pumps go bad in most vehichles is driving with less than a 1/4 tank of gas,it gets the fuel pump hot and works it too hard
Jan 19, 2013 | 1994 Chevrolet C1500
My 94 fors Taurus cuts out while driving and sometimes will not start. It cranks but won't start. We changed the fuel pump, spark plugs and distributor cap, but it is still cutting out while driving...
are there any codes? have you checked the pressure in the fuel line. you may have a bad fuel pressure regulator. or a bad crank position sensor. spray starter in the throttle body and see if it starts
Dec 14, 2012 | Cars & Trucks
Why wont my 94 accord 4 cyl start when its warm out?
A common problem with no-start Honda cars is the fuel pump relay under the dash.
I would check that first. Could also be a faulty coil.
Sep 10, 2012 | Honda Accord Cars & Trucks
Drive 5 miles and starts up fine, drive 30 miles and wont restart
Sounds like a fuel pump overheating. Drive until it wont start then check the fuel pressure. If no gauge when it wont start try some starting fluid. You should also check your fuel pump relay.
Jun 07, 2010 | 1994 Ford Taurus
Start it up then you can drive maybe ten minutes then it dies or if you turn car off you cannot get it started again it sounds as if it will turn over when starting but it wont it also sounds like it will...
well you could start with the wires because cut wires are never good but it also sounds ike a fuel pump they can heat up and shut off and they have to cool back down befor they start again unless it felt like dieing. when this happens again chck on your fuel rail you will see a valve like on your rim to fill up your tire push in the pin and if it squirts fuel out then your pump stoped working. be carefull and wear safty glasses
Mar 05, 2010 | BMW 525 Cars & Trucks
94 Honda Accord cuts out
you might have a bad fuelinjector.. while running unplug only one at a time a good injector will slow the motor when unpluged a bad one wont hope this helps
Jul 20, 2009 | 1994 Honda Accord
94 isuzu trooper turn key fuel pump runs for 2sec.and shuts off?
Can you hear a click during that 2 secounds? Thats the relay shutting off the pump just what its suppost to do. The pump does not run contenuosly, if it did it would burn up, thats what the relay is for, it kicks on and off to maintain the correct pressure to engine as needed. It will not turn back on until it resets itself because engine was not running, thats the way there designed.
Feb 19, 2009 | 1994 Isuzu Trooper
Isuzi trooper diesel jerking when driving
Hello, it is possible that the pump is going bad but, it sounds more like water in the fuel or a dirty filter or dirty injectors. I would try a fuel additive first to see if that will clear your problem. Let me know if you need any help. Good luck.
Jan 23, 2009 | 2000 Isuzu Trooper
Got a 94 trooper that will not start unless its on starter fluid.
How much pressure is in the fuel rail? It sounds like a weak pump or bad check valve. If your lucky though it could be a clogged fuel filter. Let me know what you find.
Dec 31, 2008 | 1994 Isuzu Trooper
Great Plains Industries Gpi& Fuel Pump  Logo
47 people viewed this question
Top Great Plains Industries Garden Experts
Thomas Perkins
Thomas Perkins
Mai Lor
RSole
Are you a Great Plains Industries Garden Expert? Answer questions, earn points and help others
