Question about SmartParts SP56 Digital Picture Frame
Anyone know the dimensions of the AC Adapter for a Smartparts Electronic Picture Frame. I know the adapter is 12VDC, 1A... But without knowing the size of the connector, I can't buy a generic one and OEM cost approaches the cost of the entire unit.
    President:
  • 1,082 Answers
The size ofthe plug is usually dictated by the amperage.
Or take the picture frame with you when shopping at any electronics store.
Posted on Oct 15, 2013
Testimonial: "I think I've found the information I was looking for, mostly by trial and error. The plug/connector for the external power supply is 3.5mm x 1.5mm, if anyone else needs this information. OEM adapters cost almost as much as the photo frame, while generic 12 VDC adapters as little as $3.50 if you know the correct sized connector. Now you do. :-)"
4 Suggested Answers
SOURCE: I would like to know
I had the same problem with an SPX08E. It turned out that enabling the auto light sensor was the cause!
The way I fixed it was to remove all memory cards and attach the frame via USB to a PC. Then use windows explorer to delete all folders and files on the frame other than the smartpix installer MSI. Then remove the USB and power cycle the frame. It will come up at the main menu and you then have about 15 secs to navigate to the settings page, scroll down to the reset settings tab and reset all settings to defaults. You can then transfer any pictures you want back to internal memory.
Do not turn on the light sensor or you will have to do it all over again!
Posted on Dec 15, 2008
SOURCE: SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Posted on Mar 11, 2010
  • 4090 Answers
SOURCE: Hello. We received a SmartParts digital picture
Probably more than it's worth! Many of these items were found to be defective when shipped. This is the 41st one of these I have heard about with the same problem.
If you can return it for a refund or swap for another brand.
Please rate my help++++Thanks for using FIXYSA
Posted on May 22, 2010
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
My smart parts frame has no power - any suggestions?
Use a "multi-meter" to measure the voltage and amperage output from the power-adapter.
If the values don't match the specifications on the adapter, replace the adapter.
Find a compatible power-adapter (maybe by going back to the store where you bought the SmartParts, taking your frame with you) and trying powering your SmartParts from that adapter.
If it still does not work, then exercise the WARRANTY on the device to get it repaired/replaced.
Jan 11, 2011 | SmartParts (1DPFSP01) Digital Picture...
I have an insignia 10.4"
You can buy a multiport adapter at walmart. Meaning it plugs into the wall and has several plugs that inter change. It has settings from 3volts to 12 volts. Follow instructions in the package to make sure you have positive and negative plugged in the right way.
Jan 07, 2011 | SmartParts SPX8 Digital Picture Frame
Where can I get a replacement switching adapter for my SmartParts digital frame? I am assuming that is the problem as it won't come on and was just working a very short time ago? I live in southern...
It's probably the power adaptor. Bring the frame to RadioShack and they will try on an adaptor for you. If it works, buy the adaptor. If it doesn't, you'll have to go to your local, non-retail chain, electronics store to get it fixed...
Nov 29, 2010 | SmartParts SP15MW (092566981886) Digital...
Need a battery charger for the Standard Horizon 260s. Factory says they no longer have any and offer no replacement info.
After speaking to a technician at Standard Horizon, I was able to figure out that the charge output needed to be 12VDC and 1A. Knowing this, at Radio Shack I found an Enercell 3/4.5/6/7.5/9/12VDC AC-to-DC Power Adapter (Product 273-316) and the Adaptaplug tip "H" (Product 273-340). Be sure to insert the tip to provide a Negative Tip output. Cost was $22 for the adapter and $7 for the tip.
Aug 23, 2010 | Standard Horizon HX260S 2-Way Radio
My didgital frame will not turn on. ADS-18H-4 0918G
My didgital fram will not turn on. ADS-18H-4 0918G switching adapter does have a slowly pulsing green light. But will not turn on the picture frame. Where can I get a replacement or how do i get it to work
Mar 22, 2010 | SmartParts SP15MW (092566981886) Digital...
Where to buy a ads-18h-12-4 1218g power supply
Ebay seems as good as any ....
http://cgi.ebay.com/ADS-18H-12-AC-Adapter-9v-2A_W0QQitemZ250532141467QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a54e1199b
Satisfy yourself its the right thing before purchasing (The SKU matches, but that doesn't necessarily mean.....)
Hope this helps
Mar 06, 2010 | SmartParts SP15MW (092566981886) Digital...
Dec 14, 2009 | SmartParts SP15MW (092566981886) Digital...
My Sceptre TV doesn't turn on.
https://www.adapter-chargers.com/product/delta-adp-180cb-b-ac-adapter-delta-24v-7-5a-180w-4-pin-ac-power-adapter/
Jan 28, 2018 | Dell Dimension 8400 power supply ** FREE...
Adapter
AC adapter (100-240VAC, 50/60Hz, 2A, 12VDC output)
Jun 29, 2007 | BafoTech BAFO USB 2.0 Storage Cabinet
SmartParts SP56 Digital Picture Frame Logo
67 people viewed this question
Top SmartParts Photography Experts
Tony
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
