Question about Kidde Nighthawk Combo Gas/co Detector
What does gas 211 mean on the nighthawk - Kidde Nighthawk Combo Gas/co Detector
1992 Honda CB 750 Nighthawk gas cap stuck
Hi, Jason for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Gas cap stuck
How to fix stuck motorcycle gas cap
Honda CB750F2 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Jul 23, 2014 | 1992 Honda CB 750 Nighthawk
My kidde nighthawk beeped once; shows a display of 250 and L6, what does that mean
OPEN THE BACK AND CONNECT THE RECHARGEABLE BATTERY WITH THE SMALL BLK WIRE THEN RECONNECT INTO AC POWER OUTLET AGAIN WAIT UNTIL IT DISAPPEAR ON THE WINDOW TO INDICATE DC CHARGED ALREADY
Mar 19, 2011 | Kidde Nighthawk Combo Gas/co Detector
I tested my digital carbon monoxide detector and it flashed 888 and then flashed 248 and then back to 888 and reset back to 0. what does that mean.
When you pressed pressed the Test button, it did exactly what it should. It was testing itself and the one set of numbers was for co and the other was for gas, The ' 0' means it tested fine and there is no presence of gas or co in the home's atmosphere at this time. :)
Mar 07, 2011 | Kidde Nighthawk Combo Gas/co Detector
I have a KIDDE / NIGHTHAWK Combo Smoke / CO Alarm (Model #KN-COSM-IB). It is "chirping" once every 30 seconds. I understand this is an indication of alarm malfunction. My question is: what do...
Normally, that means the battery(s) need changing.. But, hundreds people have had problems with this combo detector, it's hard to predict what it is.
But, as I said earlier, "Normally that means the battery(s) need changing." The keyword here is "Normally".
Good luck. I hope that solves your problem.
Feb 10, 2011 | Kidde Nighthawk Combo Gas/co Detector
I have a NIGHTHAWK CO2 DETTECTOR, it reads ERR & i dont know what it mean?
Should be a Carbon Monoxide detector (CO). The ERR display means the CO sensor is probably shot. Unlike most smoke detectors, CO monitors have a limited life span. Same thing happened to me and had to get a new one.
Oct 18, 2010 | Kidde Nighthawk Combo Gas/co Detector
What does the code L6 on a Nighthawk Carbon Monoxide alarm mean?
It means low battery.
Cheers
TeaCii
If you own website, addlive support almost free
Realsecurity guard to watch your cctv for $1/day
Apr 13, 2010 | Kidde Nighthawk Combo Gas/co Detector
What does code 222 and 224 mean on the kidde nighthawk combo gas/co detector?
was there also an alarm with that reading? Normally it would suggest gas leak.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 03, 2010 | Kidde Nighthawk Combo Gas/co Detector
What do codes 222 and 224 mean on co detector
Hi there.
Did the alarm also go off? Cause that normally means a gas leak.
Cheers
TeaCii
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Nov 24, 2008 | Kidde Nighthawk Combo Gas/co Detector
Gas code 210
Does the co alarm sound and display show 210? This means you have 210ppm co. This is not good. Are both the gas and co alarms goig off? Try resetting but if it's working properly you've got a pronlem. Check this link for further info: http://www.kiddeus.com/utcfs/ws-384/Assets/900-0113.pdf
Mar 12, 2008 | Kidde Nighthawk Combo Gas/co Detector
Kidde Nighthawk Combo Gas/co Detector Logo
77 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
