Question about Sewing Machines
Bobbin win der not spinning
    Champion:
  • 241 Answers
What sewing machine are you having problems with? The bobbin tire is often the cause of the bobbin winder not to spin. Most machines this part is around a dollar and every sewing machine store will have one.
Posted on Oct 13, 2013
  • jay martin
    jay martin Oct 13, 2013
    Thanks Joe Neil. I think I may have the wrong bobbin Jay.
I have a Consew 206RB-4 and cant get the bobbin winder to work.If no thread is attached to the bobbin,the bobbin will spin correctly.But when threaded the bobbin doesnt spin Ive loosened the tension
Hi Trish,
Have you checked if that wheel which spins the bobbin winder is pressed properly against motor belt which spins the machine itself, maybe its not aligned properly or it doesn't press firmly enough against that belt, or the belt itself is old and stretched and it doesn't put enough pressure on that wheel.
Sep 29, 2016 | Consew Sewing Machines
Bobbin winder does not spin
Did you find the answer? Had this machine over 10 years and no problem. Started with not filling bobbin but half way. Now it will not spin bobbin.
Sep 30, 2012 | Brother XL-2600
The bobbin shaft will not spin
make sure the bobbin winder spindle has been pushed to the right
if you've done that, & it doens't wind the bobbin then the machine
will need to be checked
Aug 21, 2012 | Singer 7422
Threading bobbin singer athena 2009
Sorry... hate to say it but modern home singers are $%#&*@.
Have you tried a new bobbin? If the "spindle" spins... the bobbin should spin. Maybe your bobbin is busted or something?
Aug 02, 2012 | Singer Sewing Machines
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Bobbin pole for putting more thread on wont spin fast tried to reload bobbin but machine wont spin bobbin fast enough to put thread on it
most likely you do not have the correct bobbin that fits on the bobbin pole.
on the bottom of the pole there may be a small knub in which the small hole on the bobbin should slip onto this holds the bobbin in palce, (if the wrong bobbin is used and if could be just a slight difference in the boobin ) the pole will not spin correctly and not fill the bobbins,
I have seen different bobbins with the same machine with such a slight difference that the owner did not realize it.
Aug 29, 2009 | Kenmore Sewing Machines
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Mar 21, 2009 | Husqvarna Viking 1
Bobbin winder won't spin
The two most common problems are that you either need a new bobbin tire, or just need to adjust the position of the winder a little closer to the hand wheel. Remove the top cover and you will see the winder assembly. Loosen the two screws that hold the assembly nudge it closer to the hand wheel side. If you move it too far the winder will constantly spin. Also, examine the rubber tire, it may have a flat spot on it in which case it needs to be replaced. If it is worn out you may not be able to tell just by looking at it.
These winders can be tricky to adjust but why not try?
Feb 06, 2009 | PfaFF Creative 7570
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
