Question about Samsung Kitchen Ranges
How to remove side panel on Samsung - Samsung Kitchen Ranges
Freeze works fine but ref side won't get cold samsung rs2530bbp anybody know what to do?
Remove the rear panel of the freezer, and also remove the vent in the fridge side. There is likely ice build-up in between the two that has to be thawed or scraped out so the air can flow.
Jul 25, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
The icemaker lever broke on my samsung rs2630sh refig
You will need to go in through the panel, remove the bolts that hold lever and remove them, then go to repairclinic.com or partselect.com, order new part (there will be pics and part #) and then install it back on to your unit.
Jan 23, 2010 | Samsung RS2630SH Side by Side Refrigerator
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
FRIDGE SIDE SAMSUNG REFRI NOT COOLING
empty frig side totally shelves too remove white plugs too lite and both panels leave1 screw in upper narrow panel remove 2 shelf supports in middle of frig carefully pull on top of wider bottom panel with constant pressure its frozen behind i took hair dryer once seperated enough at top and dethawd till panel was removable totally thawed reassemble frig works fine
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Leak on freezer side door from control panel samsung RS2534
the trim unclips, to remove gently prise off using a small knife, you may find the you have either a faulty water inlet valve or the ice flap is not closing correctly. Regards Advisor
Jul 27, 2007 | Samsung RS2534 Side by Side Refrigerator
Kitchen Ranges Logo
64 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
