Question about Garden
Toro 51950a Where are the two adjustment screws on carb?
4 Suggested Answers
SOURCE: What is proper gas/oil fuel ratio for TORO Model
50:1
Posted on Jul 02, 2010
hunter19_46m
  • 7482 Answers
SOURCE: need gas to oil ratio
Hi lcauchon...
Use a 50:1 ratio 1 pint 2 cycle oil to 6 gallons of gasoline..
Please take time to rate me
Posted on Sep 24, 2011
hunter19_46m
  • 7482 Answers
SOURCE: toro trimmer starts fine but will not throtle up
Hi tom97420
If it has a warrenty then take it back to the place of purchase, if not then you will need to remove the carb for the following procedure:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 25, 2012
Toro 824 snowblower starts fine but won't keep running and new gas new plug as well cleaned the whole carb
Is there an adjustment screw on the carburetor if there is turn it out a little at a time. This sets the amount of gas going into the carb and lets it run the way it should. I hope you have one as this is the answer to many engine problems. When you say you cleaned the whole carb did you clean the fuel jet. It won't run if the jet is dirty.
Feb 06, 2015 | Toro Garden
Toro 266d runs five seconds then dies toro dealer just worked on two weeks ago
adjust fuel screw turn it one turn out see if that gets it running if dose turn it slowly in until throttle runs smooth the screw to adjust is the h screw on carb screw mark on top h or body will have a h on it turn it out one turn only but before that try to srart sqiuirt some starting fluid in carb sart engine leave choke off hold throttle wide open should run
Aug 23, 2014 | Garden
Where are carb adjustment screws on toro lawn mower model 20017
the Tecumseh carb. does not have any adjustment screws. What is the mower doing wrong ?
Jul 09, 2014 | Toro Power Lawn Mower
Need gas to oil ratio Toro weedeater Modle 51950A
Hi lcauchon...
Sep 23, 2011 | Garden
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
Jan 14, 2011 | Toro Blowers Rake and Vac - Electric...
Mower starts fine but conks out in about a minute or two.I changed the air filter but it still stalls a minute after starting. toro mower is about 2 years old
Recheck your fuel selector to make sure it is ON. Also if this is the first start of the season there may be old gas / debris in the bottom of the float bowl. One other area to check is the bottom of the gas tank / fuel outlet port of the tank. I don't remember if this model had an in-line fuel filter but also something to check if installed.
This is listed under Toro Mower with power tools that has a 6.5 Briggs and Stratton engine.
To clean the carb passages you will need to do the following.
(FUEL SELECTOR OFF)
1. The adjustment screw on the side of the carb that has a spring on it. You need to count the number of turns it takes turning it clockwise until it just comes up snug NOT TIGHT. Then remove it.
2, Remove the float bowl and dump the contents.
3. Spray carb cleaner in the adjustment screw hole.
4. Disconnect the fuel hose to the carb and spray carb cleaner in the brass tubing hole. The cleaner should be exiting via the float needle. Make sure float assy is down....
5. Connect the fuel line. (use a spray paint can lid and catch the fuel in this step. FUEL SELECTOR on. Catch fuel exiting carb. Lift the float to a LEVEL position and feul flow should stop. DO NOT FORCE IT! Gentle lift only.
FUEL Selector off.
6. Install float bowl
7. Re-install adjustment screw/needle/spring in the side of the carb. Turn it until it just snugs up.. then back it off the number of turns it took to initially close it before removal.
FUEL Selector on... wait 30 seconds..
7. Start mower.
That should do it.
Kelly
May 03, 2010 | Toro Lawn Mower With Toro Power Tools
How to adjust the carb on Mod. 206220 Toro
4 cycle is 1-1/2 turns 2 cycle high side which is the left screw is 1 to 1-1/2 & the low side should be 3/4 of a turn
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
