There are grey bars on both sides of the screen! CANT SEEM TO FIX IT WITH THE REMOTE?
    Sergeant:
    Champion:
  • 272 Answers
Try installing the latest version of your video card drivers. Also install the latest windows updates. And or please post mode descriptive infomation, in the correct section.
Posted on Oct 22, 2013
There are Grey vertical bars on half of the screen. The other half of the screen remains black. Sound works fine. How can I fix this please?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 23, 2016 | LG Used Original 47LE5300 Remote Control
Cant get past language screen
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears frozen at the Language select screen, we have found that to be related to the Sensor Bar. Please try the following:
Ensure that the Sensor Bar cord is plugged snugly to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar. Please read the following:
The Sensor Bar has five infrared lights on each side of the bar that the Wii Remote uses to determine its position. If these lights aren't working, then the Wii Remote cursor will not display on the screen, and you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display . After making sure the Sensor Bar is plugged in and the power to the console turned on, direct the camera at the Sensor Bar so that it is displayed in the LCD of the camera. If the five infrared lights can be seen on both sides of the Sensor Bar, the Sensor Bar is working. While the position/angle of the camera may need to be adjusted slightly, the lights are fairly easy to see in the LCD display.
Nov 20, 2009 | Nintendo Wii Console
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
My Tom Tom 530 switches on ok but screen shows no signal, when outside. I have pressed the reset button problem still persists. Can you help! Thanks.
Tap the map screen in the lower right hand side where the bars are then tap the screen on the upper right hand side where the battery is. This will bring you to the satellite screen. Leave it alone for about a minute if you don't see any grey bars showing on the bottom of the screen your unit has a problem. If you do see grey bars at the bottom leave it alone and let it do it's thing. Sometimes for the first time after not using it for awhile it may take up to a 1/2 hour for it to locate the satellite's
May 08, 2009 | GPS
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen that will not show but i could still hear hear music.
try hitting the reset button on the back of the device. you might also have the hold or lock button on. look at the sides of your devise and if you see any orange then slide the bar down until the whole side is black.
If you have any more questions email me at Starburstman6@gmail.com
May 03, 2008 | Samsung Yepp YP-P2 Digital Media Player
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Verticle Bars down each side of screen
It would be in video settings mode if avail. Being a plasma it might not be available,this feature is to prevent burn in.
Mar 21, 2007 | LG 50PX4DR 50 in. Plasma TV
Computers & Internet Logo
David Payne
David Payne
