Question about Treadmill Doctor PROFORM 770 EKG TREADMILL Drive Motor
Pro-form 770EKQ stop when you step on the belt, also has a clicking noise.
Pro form 6.0 elliptical belt keeps running to side of pulleys and making a grinding noise. This creates more tension. How can I track the belt?
There is an adjustment under the machine for the rollers, use that to align the belt to run correctly.
Apr 17, 2017 | Cars & Trucks
Proform elliptical is making a clicking noise on flywheel
My 3 month-old Pro-form RE19 developed a similar clicking/clanking noise accompanied by an intermittent rumble, all coming from the flywheel. Phone support listened to it and ordered a replacement flywheel under warranty. Installer is supposed to come swap out the parts.
Dec 15, 2013 | Exercise & Fitness
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
I have a Pro-From Crosstrainer xp 580s, walking on the belt isn't smooth and it makes a squeeking noise
You need to adjust the roller tension, The adjustments are at the sides of the treadmill by the rear roller. Sometimes there is a cover over them.
Mar 10, 2012 | Proform XP 580 Trainer Treadmill
Once you step on the moving treadmill the belt stops pro-form cs7e
try standing on it then starting it, some units have a saftey curcuit that cuts th motor if there is a spike in service Voltage level this how the machine detects if you have fallen and shuts off
Jul 27, 2009 | Exercise & Fitness
Pro-Form 360P, when I step on the belt, it stops moving.
when the belt is stopped you should be check the deck if this it´s worm or the walking belt, because a probable cause is lack of lubrication, In addition should send the engine to revision, because according to what your gross probably already there are some Diode Rectifier damaged, You must know that the cause that generates this problem stems from the walking belt and the table or deck
Jul 16, 2009 | Proform XP Weight Loss 620 Treadmill
Pro-Form XP 550 Troubleshooting
My Proform 550 doess not work the treadmill is not getting any power. Wht might the problem be.
Apr 27, 2009 | Exercise & Fitness
Weslo pro tread belt
Hi, Yes it is! the belt is not free floating but travels on a slide. When there is pressure on it ( from someone) it rubs on the slide underneath. When you step off it should stop the rubbing noise. There you go, this should Fixya!
Mar 24, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Treadmill Doctor PROFORM 770 EKG TREADMILL Drive Motor Logo
54 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
