Question about Sewing Machines
I want to clean my Singer 6510 machine, It always needs me to pull down on the wheel to get it started, kinda hard to do when you're using both hands to hold the material in place! However, in the bobbin case there is a hole (where the needle plunges down into the inner workings of the machine)...is this lint or packing material stuck in there??? The manual mentions oil, but doesn't specify where or how to oil it! (page 49 (trouble shooting guide) item "the machine is noisy" states:Poor quality oil has been used...correction: Only use good quality sewing machine oil. Where do I go from here, the manual is written poorly with several grammatical errors. Eeeek!
    Champion:
  • 241 Answers
Yes this is lint that should be vacuumed out after every 8 hours of sewing. Sometimes we see this lint build up to the point the machine will break gears. Often the lint between the feed dogs and needle plate will keep the fabric from feeding.
You can purchase sewing machine oil at any sewing machine store. It is non staining and 10 weight. You can also use Triflow as another option. Triflow has a generic Teflon in it that leaves a slippery residue for a long time.
If your machine is hard to turn with the hand wheel it may be a bearing or gear issue.
You may enjoy a new machine with the control that allows you to put the needle up or down with the touch of the foot control. After using one of these you will never want to sew on a machine that does not have the pivot on the needle function.
Posted on Oct 13, 2013
  • 13 Answers
SOURCE: problem with singer prelude sewing machine!
Firstly make sure when you thread the machine you have the sewing foot in the up position or the thread will not sit in the tension and cause this problem. Also as it is a new machine it may have a small amount of oil from transport stopping the tension discs from separating. Try sliding the folded edge of a piece of fabric with the foot up through the tension unit it may clear the oil away.
Posted on Aug 27, 2008
  • 13 Answers
SOURCE: My machine will not sew
When sewing anything that is rubberized you should use silicon spray this will help the fabric move along and will keep the needle from accumulating the rubber buildup and sticking in the bobbon casing.
Posted on May 27, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
  • 1788 Answers
SOURCE: Sewing machine works fine as
Go to singerco.com and download a manual for free, you are not threading it right
Posted on Aug 30, 2010
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
I have a Singer Scholastic 6510 and when the needle is going down the thread is not catching.
Remove the bobbin. Thread your top thread just as normal. Now turn the wheel toward you and watch the area where the bobbin normally be. You should notice a sharp object (hook) pick up that thread just as you continue to turn the wheel. If it doesn't pick it up then the needle and hook aren't meeting at just the right time. This will mean that your machine needs to be timed.
Aug 29, 2011 | Singer Sewing Machines
Machine will not turn over.Motor runs and cogged belt runs. Clutch?
Have you checked the cluth in the handwheel is not set for bobbin winding....it is a half turn of the centre wheel or a push pull action, not certain of this model.
Jul 31, 2009 | Singer 6510 Sewing Machine
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
Need manual to know how to set tension. Singer Sewing machine Mod.#5932 Serial#N319411147
Singer Machines are probably the easiest to set..
first thing you need to do is remove the thread..
Set you tension knob/wheel to the middle number.
When you rethread the machine, stop when you get to needle. Put the presser foot down and pull the thread. If it pulls hard then so far so good. If it pulls easily, the thread is not thru the tension wheel right. Thread the needle and stitch about 10 inches on a medium wt fabric.
The stitching should feel even on both sides. If the top still is tight, loosen it up just 1/2 number.
So, if your middle number is 4.5, turn it to 4. If it seems loose, turn it to 5.
Kelley
Apr 30, 2009 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
