Question about Dryers
Lg dryer error codes
D90 code and dryer stops
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Duct is plugged it is heating up. the vent needs to be cleaned.
Posted on Oct 13, 2013
  • 3 Answers
SOURCE: Dryer error code
is the dryer getting hot?
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Posted on Aug 22, 2010
  • 537 Answers
SOURCE: my dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Posted on Apr 18, 2009
SOURCE: Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Posted on Jun 28, 2011
richroth
  • 9472 Answers
SOURCE: bosch dryer error code F11
Sorry to be the bearer of bad news.
F11 indicates a fault with the main control board.
Posted on Nov 01, 2012
richroth
  • 9472 Answers
SOURCE: Code error "6E" on Dryer LG td-c70210e
ok so 6E means that your thermistor is out of range
Posted on Nov 24, 2012
LG washer dryer WD1485RD showing error code FE. Will not stop pumping water into machine/ cannot finish the cycle
Try first unplugging power cable for two minutes, this can clear error code if there is no real problem with your appliance.
Aug 16, 2008 | LG Washing Machines
I have a LG dryer model DLE5932W with a error code of HE
I'm sure you have fix the situation by now, but could the error code be a "HS" and not a HE? HS is a humidity sensor issue. often the metal strips below the filter on the inside of the drum are coated with fabric softener and cause issues. clean them with goof off or denatured alcohol will often fix issue. sometimes(rarely) one of the connectors comes off and causes errors. if you are still having issue, post a picture of the error code as a comment to your original post.
Aug 31, 2016 | LG Dryers
I have an LG Dryer and keep getting a error message D90 after running for about 10 minutes
D90 means the dryer thinks the vent duct is 90% blocked. Be sure the vent hose is not kinked behind the dryer. I've even disconnected the hose from the dryer and hooked up my leaf blower to blow out the vent as it develops more air pressure than the dryer does.
Here's a great video describing the error code: https://youtu.be/yL7Oq4lCadw
Good luck. Hope this helps.
John
Mar 22, 2015 | LG Dryers
Why does DLE4870W dryer keeps stopping with d90 error. but their is no blockage of air flow.
Check the link first before going forward!
The next step is more involved and you may want to call for service. Normally you will find a wiring diagram attached to the dryer, take a look underneath or some are found by removing the back cover. Take a look at the wiring diagram to see if there is a temperature duct sensor wired in, I would suggest changing the senor, but only after you check the link and call the support center found at the link!
Looking for Answers about LG Electronics DLE4870W
Nov 29, 2014 | Dryers
Error code ee3
TE3' error code - Heating Error - High temperature thermistor open circuit. Could be the thermistor, high temp thermostat, etc. It shows an "open" code, which means something from point A to point B is open, and not grounding out. Check wiring, plugs, anything that could be bad or disconnected.
Nov 07, 2013 | LG Electronics DLEC855W Electric Dryer...
"error code" r33
Is this keeping you from shooting? Normally this is an informational message telling you how many more shots you can take in the current burst before the buffer fills up and the camera has to stop shooting and write to the memory card.
Sep 09, 2013 | Nikon D90 Digital Camera with 18-105mm...
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
Dryer does not spin dry, water left in drum...Error code OE
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 02, 2011 | LG Dryers
Dryers Logo
2,421 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
