Question about Xerox DocuColor 12 Printer
Ricoh mpc 6000 and with a fiery e-7100 disk full message how to clear
I ran memory clear on Ricoh Mpc7500.Colour document appears double.Run force line position with sp2111 still no + result. unlike other mpc where you have a, b and c to execute, Any idea pls
kindly ensure there is enough toner in the machine and as well ensure that the transfer belt and unit is properly claen .
you can then run the force line adjustment.
goodluck
Jan 02, 2016 | Ricoh Aficio Office Equipment & Supplies
I am getting a 'disk full' message on the Fiery. How do I delete it?
TROUBLESHOOTING
This chapter provides troubleshooting tips.
Troubleshooting the Fiery
Startup diagnostics are described in the documentation for service technicians. Contact your
authorized service/support center if you see error messages while Command WorkStation is
starting or if the Fiery does not reach the Idle state.
Runtime error messages
For error messages related to canceling jobs and printing, including the Disk Full message and
alerts to load media, see Command WorkStation Help.
For error messages related to the copier, see the documentation that accompanies your copier.
You can turn on PostScript error reporting as a print option from Mac OS applications.
Printer not found
Most failures to find a printer on the network are due to conflicting or missing name or
address settings for the Fiery. You must type names in specific places. The required names are:
•TCP/IP host name (also known as the DNS name), which is defined by your organization.
Type the host name as the Server Name in Fiery Setup.
•Remote printer (internal machine) name. Use one of the following:
print
hold
direct
NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you
must reconfigure one of the utilities on each workstation. http://swdownload.efi.com/ftpvefigs/9019710383/2822679259/9432346727/7795362481/Configuration.pdf
Dec 12, 2015 | Xerox DocuColor 242-252-260 PS
Ricoh mpc 6000 hdd change
hello when i replace two new hard drive in the machine sais can,t not format the hard drive can somebody help me to fix the problem
Jun 04, 2014 | Ricoh Aficio MP-C6000
How to enter service mode for ricoh mpc 3003sp
YOU NEED TO PRESS C BUTTON(RED) LATER PRESS KEY 1 , KEY 0 , KEY 7 & HOLD THE YELLOW KEY FOR SEVERAL SECONDS, THEN THE MACHINE WILL ENTER SP MODE
Sep 23, 2013 | Ricoh Aficio AP3800C Laser Printer
Need full reset of Lexmark X66
i can firmware ricoh MPC 6000. pls sent to me phamgia6688@gmail.com.
thanks you.
Jul 05, 2013 | Office Equipment & Supplies
Firmware ricoh mp 4000
i can firmware ricoh mpc 6000, please sent to me phamgia6688@gmail.com.
thanks!
Aug 17, 2012 | Ricoh Aficio Mp 4000...
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
