Asus motherboard problems Installed a new F2A55-MLK series to replace old ASUS board. Running XP and when I install the HDD it boots until the starting windows screen and get blue screen Asus tech no help.
  • 212 Answers
Go into the BIOS setup and find settings for SATA operation or something similar. the available options should be
1. Native SATA/IDE
2. AHCI supported
3. RAID
windows xp was installed with SATA support but requires special drivers for AHCI or RAID, so you should set your computer's SATA operation to native or IDE in order to solve the problem.
Additional tip:
next time you manage to boot to windows, boot to safe mode (boot while pressing F8), so you can review if all the drivers are well installed in device manager.
Posted on Oct 14, 2013
map9966
  • 2351 Answers
SOURCE: Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Posted on Sep 26, 2008
benwabnick
  • 2404 Answers
SOURCE: asus p5pe-vm series motherboard driver wont work with windows 7
Windows 7 is still in the beta/testing stage from what I remember.
If you go to this page courtesy of ASUS:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the search box type in your motherboard p5pe-vm and click on P5PE-VM related files for download
It will come up with a seperate window that will ask you the OS that your installing and windows 7 is not an option which tells me that drivers aren't available for your motherboard just yet, it may down the line once windows 7 becomes publicly available.
Posted on May 04, 2009
  • 256 Answers
SOURCE: New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Posted on Jun 25, 2009
  • 336 Answers
SOURCE: Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Posted on Sep 11, 2009
hacker8499
  • 74 Answers
SOURCE: asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
Posted on Oct 14, 2009
I have a HP Pavilion Slimline running Windows 7. I had to replace the motherboard with ASUS F2A55 - MLK. Now I get a 'Configuration Error' when I boot-up.
HI,
You cannot just replace the motherboard and then install the same Hard Drive and expect it to work. It CAN work, but you have to prep your Hard Drive before you switch motherboards.
Your Operating System, if already installed on your Hard Drive, is configured/locked to your old motherboard. You would have to run SYSPREP or some other software on your COMPLETE system before switching out your motherboard, to UNBIND all the hardware and drivers already installed in your Operating System. This would make it ready to be installed in a new computer system... which yours is with a motherboard change.
The only option that I am aware of is to completely reinstall your Operating System from scratch... however, if your old motherboard is still functional, you might be able to put your old system back together and then run the appropriate software (search online), which could save you some time.
Jan 27, 2014 | HP Hewlett Packard Pavilion Slimline...
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
Asus mb wl300 amd 64 4000+ won't boot to bios.
To make sure it isn't anything else, pull all cards, and drive cables from the board so the only thing left connected is the power connectors to the motherboard, the speaker, and the power button. Pull all the ram cards.
Now power up the computer. If you hear a series of beeps then the computer recognizes there is no ram on the board. At this point I would take the power supply out and have it tested. If you do not hear a series of beeps I would still have the power supply tested as it could be the 12v is fine but the 5 and 3.3 volt side is bad.
If power supply tests good then I would replace both the motherboard and processor. You take a risk of burning a new processor if it's the motherboard causing the problems.
Jan 08, 2010 | ASUS Computers & Internet
Asus P4pe2-x motherboard problem with windows xp
yes just power switch was replaced just need the diagram on where hdd and reset swich all goes
Dec 03, 2009 | ASUS P4PE2-X Motherboard
Asus p5rd2-vm audio driver
double check if your audio driver is really installed, it's in the device manager area, if it's really installed maybe you have just muted your speakers, but if it doesn't work try to install a new speaker or headphone...goodluck
Jul 10, 2009 | ASUS P5RD2-VM (1191992) Motherboard
I need to install drivers on an old HDD for an Asus K8V mobo.
Hi gordonal123, installing drivers through safe mode is not recommended. If you want windows to function correctly than do a fresh install of windows. Over writing the Gateway hdd will cause you more grief. Windows registry will go nuts.
Link to download the Asus K8V drivers.
Here is what you need to do. Boot to your windows CD while using the Gateway system & hdd. Create a new partition within the free space of the Gateway hdd. (Follow windows onscreen instructions to create a new partition within the free space of hdd). (This will maintain the current windows function).
Restart windows when finished. Windows will create a second partition on the Gateway drive. Go to the Asus link above & download all the drivers for the K8V MB, onto the second partition of the Gateway hdd. Once downloaded & uncompressed into their own folders you can than boot to the windows CD & format the primary partition & install windows fresh onto the formatted partition. When finished you can install the K8V driver still located on the secondary partition. Copy & past these driver folders to your primary partition. Than use windows disk management software to erase / delete the secondary partition. (diskmgmt.msc).
When finished you'll have all the drivers for the K8V MB, no need to buy a PCI LAN card & more importantly a fully functioning windows with-out issues.
Good luck gordonal123!
Take your time.
Mike
Dec 30, 2008 | ASUS Computers & Internet
Could not detect HDD on my Asus P4B-M Motherboard
hi,
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Asus pp5gcx motherboard-realtek hd audio driver" failed to install"from cd.
go to the support site for your motherboard, there you will get universal bus architecture device drive. Install this before you install the Audio/Sound driver.
Apr 14, 2008 | ASUS P5P800-MX Motherboard
ASUS P4S533 mother board not supporting full 160 gb
This is happing becuase of your motherboards BIOS !
Really, this happened to me too. You see, our motherboards which are very old cant support above 80 and so on. This is beacuse of the BIOS. You will need to update your BIOS inorder to give new features.
Try go to the Asus home page and download the latest driver for your motherboard. Then install it in your motherboard's BIOS. There is intructions for this in the Asus's home page.
Mar 08, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
