Question about Samsung HMX-H304 Camcorder
I need help fixing this camera
Camera is dead, battery is fully charged and have tested with mains charger attached. will not switch on. when charging, has 2 blue lights on rear panel. can anyone help me fix it?
  • 5 Answers
SOURCE: Wont hold charge, light comes on though
hey , well i think an hour might be normal , mine seems to only last as long , but it says in the manuel that when the camera is not in use to disconnect the battery because even with the power off it still discharges.
hope this helps
Posted on Jan 03, 2008
SOURCE: NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Posted on Jul 09, 2008
SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Posted on Nov 18, 2008
SOURCE: When charger is plug in, battery icon changes to
on the top the red light is glow which means battery is charging when full charge it becomes green
Posted on Oct 19, 2009
  • 61 Answers
SOURCE: won't charge batteries, won't run on outlet
look at bottom of ac charger check output voltage ...see wether it`s same as battery voltage..
Posted on May 19, 2010
Charging camera
I think that your batteries may have expired due to old age and are refusing to hold a charge.
Ni cad batteries have a shelf life and once that time limit has expired, you need to replace the batteries with new ones which will begin counting down to their expire date and also go dead.
once ni cad batteries have expired and past their time limit
nothing can be done to revive them ,they are forevermore dead and must be replaced.
that is the reason why i buy 120 volt ac drills instead of battery powered drills which are always dead by the time i need to use them and wont hold a charge when i try to recharge them.
my cordless radio phone batteries go dead after 1 hour on the phone, when they were newer,i could talk for 4 hours and still have 1/4 charge left. soon they will only last 30 minutes and need a 12 hour recharge to come back to 4 bars.
so i expect to have to pay 4 new batteries by christmas.
One other option may be that your charger is not working properly and developing the required voltage.
that also happens but not as often as dead batteries that wont hold a charge.
if you have a radio shack nearby, even if its a 20 mile drive
they can test your batteries and also test your battery charger. just ask for a salesman that has a battery tester and a vom [volt,ohm,milli amp meter] also called a multi meter. The vom will test your charger and came also test your batteries, but most salesmen dont know enough about the vom to use it as a battery tester .
PS a battery tester is just a vom scaled down for battery testing only, made easy to use for dummies.
Oct 09, 2013 | Pentax Optio Cameras
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I have a sony Handycam (DCR-SR65) model, the battery is loaded but the camera won't switch on, it looks dead!
Is the battery fully charged?
If you connect the camera to the charger same happens?
Try charging the battery or test with a different battery.
Apr 05, 2011 | Sony DCR-SR47 Camcorder
Batterie
You tom tom uses a lithium ion rechargeable battery that lasts at least four hours after charging it fully. To charge it fully, you need to connect it to a charger and allow it to charge for about 2-3hours, if he battery is weak it will loose charge easily loosen its strength easily and if it is dead, it will not hold a charge at all.
What exactly is wrong with your battery? if it is not holding a charge, then i will advice you you first try to use it on another device and plug it for about 2 hours before using it in there, if it works, then it means your battery is still working perfectly fine, but if it does not, then it means the battery is dead and needs to be replaced.
Test your charger also by using it on another device to see if it will charge the device, if it charges it, then it means your charger is alright, but if it does not, then it means the charger is faulty that is why it is not charging the battery. And all you have to do is replace the battery.
Also you need to test the device, by fixing another well tested battery into it, and using a well tested charger on it, if it does not come on, or seem to charge, then it means there is a problem with the connection port or something with the unit.
Hope this information helped.
Jan 07, 2011 | Tomtom GO 700 GPS Receiver
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
BATTERIE DEAD...WONT CHARGE
REmemeber if you're charging the batteries though the computer NOT to switch the camera on. In order to determine the exact fault for your no power issue please try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak Easyshare M753 Slim Digital Camera
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
It will not switch on, even with fully charged batteries
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M853 Digital Camera
Battery will not charge
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair, order a new battery, charger or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak MX1063 Digital Camera
Have a kodak m1033 that seems to be frozen in the "off" mode. Have replaced the battery twice, works for a day or two then won't/can't charge and can't get the power light to come one even with the charger...
All Technical equiptment can have problems Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 19, 2009 | Kodak EasyShare M1033 Digital Camera
Samsung HMX-H304 Camcorder Logo
16 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
