Question about Stryker 20l High Flow Insufflator
My stryker 20 l hi flow insuflator shows malfunction and E04 what is it, and what can I do
Where do I adjust the cable on a kymco striker 125 but it has a 200cc xg Joa motor
Hi, Tony for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Kymco Stryker 125 150 Service Repair Manual Download Download Manuals... $10
Stryker II 125 DA25BB DA25BD Kymco Scooter Parts Racing Planet USA
KYMCO Stryker 125 User Manual FREE
Oct 11, 2016 | Kymco Motorcycles
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
Since you said you replaced the fan, and flow valve. Did you re-install the pressure switch correctly? it will look something like attached image. This is more than likely the cause if you did not replace with the fan or reinstall correctly... or it might have been the cause in the first place...
What is E 21 In insufflator
What is E 21 In insufflator - Stryker 20l High Flow Insufflator
May 14, 2014 | Stryker 20l High Flow Insufflator
Bike is running very hot, sounds like the engine will not decelerate. Engine is reving while stopped. Engine light has come on.
Hi, Kenamo13 and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Stryker running hot
Engine Overheat
2011 2013 YAMAHA STRYKER 1300 Service Manual Repair Manuals AND Owners... $10 cheap
OEM parts for Yamaha
Yamaha Star XVS13CB Owner Manual
Jul 20, 2011 | 2011 Yamaha Stryker
Bobby_somebody can show me finals of a stryker sr 490 picture or rwite them pleaseee
Hi bobby,
Welcome to FixYa.
My name is John. I will be assisting you with this issue.
The Stryker SR-490 has the SD-1446 flange mounted transistor in it.
You can get it here www.dubscbshop.com. #217-826-2763
Hope this was helpful.
Thanks for choosing FixYa.
John
Jan 18, 2011 | Radio Communications
I need to replace my starter motor for my kymco stryker. Do you know any compatible parts that is exactly the same as my kymco stryker?
i need to replace my starter motor for my kymco stryker. do you know any omcpatible parts that is exactly th same as my kymco stryker
Oct 03, 2009 | 2001 Kymco Stryker 125
Where can i get mannual
hi m8 dont know about the manual but if u go to ebay.com and tape in kymco stryker they have loads of engine parts hope this helps m8.. will g..
Jan 26, 2009 | 2001 Kymco Stryker 125
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Stryker 20l High Flow Insufflator Logo
66 people viewed this question
Top Stryker Science & Laboratory Experts
William McMath
ray gallant
Are you a Stryker Science and Laboratory Expert? Answer questions, earn points and help others
