Question about Lowrance Boating
The transducer on my Elite 5 is making a clicking noise
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
Replace it or get another one that's good see if it does the same thing
Posted on Dec 19, 2013
The depth finder on my elite 5 Lowrance blinks if I go over 14 mph. And the screen gets very hot after a few minutes of run time?
Hey Robert,
the blinking is usually the result of the transducer losing contact with the water..
As far as the screen getting hot.. that is not good.. do you have this unit mounted in dash? It needs some ~cooling.. just some airflow..
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Aug 28, 2016 | Lowrance Elite 5 Color SonarGPS Combo
Elite-5HDI Screen is frozen and unit will not shut off.
Hi Thomas
I think your best bet here would be to contact Lowrance support directly I've included the link below.
-Steve
Contact Us
Mar 08, 2015 | Lowrance Elite-5 HDI with 83 200 kHz and...
My elite 7 won't read depth when boat gets on plane
The transducer MUST be in contact with the water for it to operate properly. Check and make sure (if it is a thru-hull) that the ducer isn't in the air when you're planing. I've read that wiping the transducer with Dawn dish detergent speeds up the "wetting" of the transducer and makes for a better contact with the water.
Hope this helps.
-Steve
Feb 26, 2015 | Lowrance Elite-7 HDI...
Why does my lowrance elite 5 not read bottom when boat is moving
If the unit reads bottom sitting still but doesn't when moving it's due to air bubbles passing over the transducer face. Go to Airmar website and search for installation instructions.
Sep 06, 2014 | Lowrance Boating
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
Kenmore elite, oasis, model # 110.2703, at exactly 19 min left, at the starting of the rinse cycle it flashes the F1 code, i push stop then start untill it stays on, usually takes about 4-5 trys
Thank you for your question.
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
The first image below shows the method for accessing the pressure transducer tube that runs from the bottom of the washer tub to the machine control. I recommend checking this air hose for pinches, twists or crimps.NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below.
Jan 09, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Re: transducer installation should the transducer on a Elite 5 be in line with the bottom of an aluminimum hull or the bottom of the ribs running along the hull thanks
try and mount the transducer at the lowest point on the hull and on the flatest part,, with the direction arrow facing forward.
c...
Jan 04, 2011 | Sport & Outdoor - Others
Boating Logo
107 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
